Results 1 to 6 of 6
Thread: D4 Second battery cover
    Feb 2012
    Heddon Greta NSW
    Lightbulb D4 Second battery cover
    If anyone is concerned about their 2nd battery getting to hot under the bonnet then this may help!
    I have found using the battery cover from a 2003 TS Astra helps reduce the heat from the engine. I was surpised at how well it works and the fit is great! I think it looks better too.
    Glenn
    Good idea
    Sep 2012
    Looks to be a soft insulating material; source from wreckers I suppose?
    Feb 2012
    Heddon Greta NSW
    yes it is soft! and no couldn't get any around here so I knocked off the wifes lol the Disco needs more than the Astra.
    Queensland
    Quote Originally Posted by Rollin over View Post
    Your a brave man
    May 2012
    Townsville
    Does the battery (yellow top optima d34 ) need air flow to keep it cool ? One would think this cover could actually raise the temp. If that was the case.
    Any thoughts here on this theory. There must some engineers on this forum who can help.
    Otherwise all batteries would come with foam insulating sleeves or aftermarket ones.
    RB
