Results 1 to 4 of 4
Thread: Visual Basic
    Nov 2012
    Now living in Forest Lake QLD, no better place to be
    Visual Basic
    Is there anybody in the southern side of Brisbane that knows about Visual Basic. I am trying to get my mind around it and having some what heaps of problems. If you could help I would really appreciate it.
    Oztruckdriver
    WASN'T ME OFFICER, I WAS GOING THE OTHER WAY
    You want to try to explain what your problem is?
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Nov 2012
    VBA
    Being doing tutorials on You Tube to learn.
    Saved my projects.
    Did a project tonight, just practicing.
    THEN
    Lost the contents of the TOOL BOX
    Lost the contents of the PROPRTY WINDOW
    Closed evrything down.
    Went back in. opened new project and everything is fine.
    Tried to open any and all of the saved projects and the Toolbox and Property window is empty in all of them, hence I can not open any saved project as I was opening them through the property window.
    I have done something wrong to upset the Gods.
    Are you talking about using the old 'Visual Basic' or are you talking about using VB.Net under 'Visual Studio 2010' or maybe 'Visual Studio 2012'.
    If your talking about the old 'Visual Basic' then I probably can't help but if your taking about VB.Net under Visual Studio then there are two things I can think of first up.
    1)The tool box and properties windows must be opened to view them. To open the 'tool box' go Menu > View and choose 'ToolBox'. You can then close, or hide it as needed. To open the 'properties' window right click on any object in the 'Solution Explorer' and chose 'Properties'
    2) Regardless of 1 above - you won't see any 'tools' in the 'tool box' window unless you are viewing a form's designer.
    In 'Solution Explorer' look for a form (I assume you have created one in one of your tutorials) and right click on it. You should see a drop down menu that lists 'View Designer' and 'View Code'.
    If you view the designer your tool box window will be populated with tools. If you choose to view the code your tool box window will be empty because there are no valid tools you can use when viewing the form's code.
    Maybe that helps.
    1984 RRC, in hell
