Check the Books History,
If all serviced as required then a possible purchase - make sure you factor in an extended warranty from Allianz, worth every cent.
Regards Rich
Lads
I am looking at a D3 HSE TD6 at Alto landrover in Sydney, does any body know of a good mobile landrover mechanic who I could get to go and do a pre purchase inspection for me.
Thanks Declan.
Regards Rich
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
Declan, you could contact Cremorne Prestige, they are just down from Alto's in Hotham Parade.
Regards,
Glenn
Not a Landy mechanic, but a good 4WD mechanic is just around the corner. Either Eddie or Chris at Artarmon Automotive should know 4WDs, except for something very specific.
Also just around the corner is GregPearson at Cremorne Prestige, a D4 owner, member of the Range Rover Club and he knows his Disco's. others here have discussing a roving mechanic, but I think he mainly works on the south side.
Lads THANKS for all the replies I have Greg Pearson at Cremorne Prestige who is only a couple of hundred meters down from Alto is going to do a pre-purchase inspection ,hopefully everything goes well as I really want to get into a D3.
Thanks Declan.
Lads pre-inspection for my D3 failed so looking at 1 in Brisbane , any good landrover mechanics up there I can get to do a pre-inspection on a D3.
Thanks Declan.
Declan,
Take it to MR Automotive in Redcliffe. If the seller won't let you get it looked at, walk away!
Nino.
