Results 1 to 10 of 12
Thread: Output shaft differences between ZF auto and LT77?
    Aug 2010
    Sunbury, VIC
    Quick one - is there a difference in the 10 spline output shafts between an LT77 from an 86 Range Rover and a ZF auto from a Disco 1? I'm just trying to put the original Range Rover transfer case onto a ZF from. D1 and I can't get it to fit...
    I thought they would have been the same - they look the same, but I can't get a measurement on the input of the TC.
    Is there a difference, or is it just operator error...?
    I'm hoping it is the latter and I'm just being a retard....
    Cheers - Gav
    Jul 2008
    Ballarat, Victoria
    I thought they were the same, this is going to sound silly, but are you using the spud shaft for the ZF?
    Maybe there are some burrs on either the output shaft or inside the input gear of the LT230
    I had a bit of trouble fitting the LT230 to the LT77 in my tdi disco and found that with the centre diff locked, wiggling the output flanges while pushing the box on helped locate it better
    Kingston, Tassie, OZ.
    Gavin, if it goes on all bar about 25mm, then check very carefully the spline depth, you may have bottomed out in the input gear. There were several different input gear splined lengths, the internal spline that is in the transfer case.
    JC
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by jazzaD1 View Post
    Tried all the wiggling stuff while turning the output, and no burs in the output shaft. What is the spud shaft you mentioned?
    JC
    Thanks JC, but I'm not getting anywhere close to that - I just can't get the shaft to engage with the input on the TC... I'll measure that though before I try again.
    Cheers - Gav.
    Jul 2008
    Ballarat, Victoria
    this is the spud shaft i'm talking about, it adapts the output shaft of the ZF to a 10 spline shaft for the LT230
    also if you need to, you could remove the input gear from the transfer case to see if you can get it to mesh with the ZF
    Gav, It might be burred like Jazza suggests then. If the spline wear is excessive on either external or internal splines, then you will have the devils own trying to fit another or worse still a new one in.
    JC
    Aug 2010
    Sunbury, VIC
    Yep, that is there. Don't really want to pull the input shaft out the TC - I've only just put it all back together.... or does the spud shaft come off the box easily?
    I'll have another crack in the morning and failing that I'll pull it apart again. Another forum member is coming over to give me a hand, so hopefully between us we can get it to work.
    Aug 2010
    Sunbury, VIC
    JC
    I'll have a closer look at that. There was no easily visible wear on the LT77 output shaft when I removed it and none evident on the auto. I didn't check the input shaft splines closely while I had everything apart though.
    I'll see what the new day brings.
    Thanks for all the advice - Gav
    Crafers West South Australia
    Are you using guide pins to refit the transfer case? Cut the heads off two 200mm long 10mm bolts and install them in the back of the trans. These help the transfer to go on straight and not damage the seal. Spin them out when the other bolts are in and put the last two bolts in.
    Aug 2010
    Sunbury, VIC
    I was only using the studs on the back of the box to line things up, but your idea sounds like a goer - thanks.
