9th January 2013, 01:18 PM
Turbo wastegate actuator pin
Has any body had the wastegate actuator pin (wastegate not the actuator) snap off. Mine did yesterday. I have replaced it with a small bolt and several nuts as a temporary measure. Is there a replacement setup as it seems to be part of the wastegate itself.?? Its a very bad feeling driving with no boost
Cheers Dave
11th January 2013, 09:41 PM
Hi Dave, have you had any progress with this?
12th January 2013, 04:17 PM
Yes, managed to drill out the old pin and put a small bolt thru the wastegate lever and use a couple of nylock nuts with washers to keep it located and alow it to swivel with the actuator. Seems to be working quite well.
Boost is back to normal.
