Results 1 to 4 of 4
Thread: lt230 rock crawler gears
    88classic Guest
    Post lt230 rock crawler gears
    Can anyone tellme if anyone in Aus can do the lt230 transfer case with low range only rock crawler gear set also steel bushing to stop the usaul oil leaks
    asseen on the ascroft design??
    Nov 2012
    penrith
    I hope so I would like some for my truck
    At one point Ashcroft were offering a replacement low range gear set for thr LT230. AFAIK it is no longer available. Im not sure why they stopped, I did here RUMORS that some failed...but these were only internet words so could be BS. Ashcroft still do the bolt on underdrive crawler box.
    Maxidrive developed 2 low range gear sets for the LT230. one at 30% lower than stock and the other 49% lower. These are still available from M R Automotive in Brisbane. I would give them a call and see whats up.
    88classic Guest
    crawler gears
    Cheers Thankyou for that i will lookthem up tomorrow
    The gen 3 rangie came with a very upset lt230
    soI have 2 replace it so might as well put some crawlers in for rough terrain
