The bulb will be H4. No not of the other.
Cheers Hall
Got a set of non-sealed beam headlights in the Deefer as MANY of you would have.
What type of bulbs to do I need - H4 ? (One has blown and its such a palaver to get at it I thought I'd ask first.
The other thing is that behind the headlight there is a black "ring" thing which the headlight fame kinds of screws too sort of like a bayonet fitting (IIRC). Anyway the ones I have a cracked, broken, not very useful.
Anyone know what I'm talking about? If so, are replacements available? Ideally good quality ones?
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
Cheers Hall
I want the philips (or similar) "white light" type. Don't want them to be blue. What color temp (degrees kelvin) should I be looking for?
Presuming something around 5000K?
This is the Philips link
http://www.lighting.philips.com.au/v...ictionID=12571
I THINK these are the ones I have in there at the moment one of which is blown
http://www.lighting.philips.com.au/v...%20light_car#0
although it may be another brand.
These are the only 100/90 W ones in the range of H4 bulbs (I have a traxide wiring upgrade) all the others are around 60/55 or thereabouts.
IIRC Supercheap etc charge around $45 or so for them (Edit: for Calibre brand) and around $70 for NARVA
http://www.supercheapauto.com.au/onl...05#Description
but there must be somewhere cheaper?
gone
1996 Discovery 1
current
Best not to go past 4500K on the bulbs and in fact I'd try to stick below 4200K which will still be slightly blue.
The bowls your talking about are these:
S5400 | Headlamp backing bowl - complete with chrome ring and fixing screws
Shop around, check eBay etc, you can also find them in stainless.
I found out I want more like 4000K or the light looks quite blue to others. Don;t want that kind of attention.
These (Philips Blue Vision) although only 60W are less than $30 online and might do the trick.
Philips Blue Vision Ultra H4 (Twin Pack) | PowerBulbs
I'd be very interested in what others have in their Defenders and their experiences with them.
gone
1996 Discovery 1
current
Found this neat little how to remove and refit headlights, basic but nice to have pics
http://www.landyzone.co.uk/lz/f41/he...al-130728.html
As for the bowls -
Checked ebay - there are very few listings
7" Headlight Headlamp Bowls Range Rover Classic Land Rover S2 S3 Defender 90 110 | eBay
are the same as the Paddocks ones.
approx $59 incl shipping
or these USED ones for TWICE THE PRICE
LAND ROVER DEFENDER HEADLIGHT HEADLAMP BOWL COVER AND SEAL X 1 | eBay
This mob seems to have just the one...
HEADLIGHT BOWL FOR A DEFENDER 90/110 | eBay
Any other suggestions where I might try?
What are Paddocks freight charges like?
As for the bulbs -
There are only the rally style 100/90s which will officially be non ADR for road use but would they actually be TOO bright?
http://www.ebay.com.au/itm/2pc-Phili...#ht_2670wt_775
I dont think there's be any leccy dramas as I have the traxide relay kit, but perhaps a 60/55 would be enough?
If the latter the cheapest CrystalVision ones are from here
http://www.ebay.com.au/itm/Philips-C...ht_1726wt_1008
Ironically the former (Essential Power) are MUCH cheaper than the latter (Crystal power).
gone
1996 Discovery 1
current
anyone?
gone
1996 Discovery 1
current
