Results 1 to 10 of 18
Thread: Boat fails to proceede
    Williams West Aust
    Guys
    Any help appreciated.
    2003 75HP Merc 2 stroke.182hrs on clock.
    Every trip,ie several days fishing,or even a single outing,my boat looses power and stops once.Re-prime the bulb and she goes as if nothing happened.
    Before my Albany trip I replaced the fuel lines,prime bulb and fitted hose clamps instead of zip ties.
    Yesterday she stopped again,on the 5th trip in 6 days.Same story,squeeze the bulb and away we go.The bulb did have air in it.I have a 120lt in hull tank,oil injection.
    HELP,the Mrs wasnt too happy.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Ean Austral Guest
    Gday Andrew,
    Is it possible that the fuel tank breather is getting blocked or pinched by something and when you move to restart the engine it comes free again... Dont laugh when we had the hire boat business this happened to us on more then 1 occasion.
    Just a simple start point.
    Cheers Ean
    Williams West Aust
    Ean.
    I bought enough fuel hose to replace the 2 breathers at the same time,only to find they are bigger diameter than the main fuel line.
    1 of the 2 hoses does have kinks in it,its the one on the fuel fill side.Fuel squirts out of that breather first when filling so I thought it should be OK.
    Andrew
    Jun 2010
    Fremantle
    A mate had the same issue, new elcheapo hose fixed it.( complete hose, priming bulb and ends)
    Sounds like it could be sucking air?
    03 Disco 2a, TD5, Olso blue, 7 seater, Auto, Chipped, EGR'd, 2"lift, SLS, Dual Batteries, Provent, TM-2 engine saver
    Racer-X Guest
    Check the fuel pump
    Hay Point
    Does it have those quick connect fuel couplings where the hose attaches to the motor Andy. If it does that could be the problem. They have a small o ring inside them, which may need replacing. Even a small nick in this o ring can cause air to be sucked in.
    Cheers......Brian
    1985 110 V8 County
    Ean Austral Guest
    G'day Andrew
    Remember a underfloor tank will have baffles in it and if the breather on one side is not working it could be enough to restrict it enough to cause the problem. It seems that once the suction from the fuel pump stops and it can pressurise enough and you prime the fuel back up it goes again.
    Cheers Ean
    Nov 2012
    penrith
    Could be a little air leak and its just enough after a period if time to stop the fuel pressure?
    Williams West Aust
    Quote Originally Posted by Bearman View Post
    No quick connects,plumbed from tank to large filter and then prime bulb/motor.
    Andrew
    Williams West Aust
    Quote Originally Posted by dswatts View Post
    Is all new Dylan,prior to going to Albany.
    Andrew
