Fail to start disables all electrics
Easiest to explain what has now happened twice in the last couple of weeks.
On the Puma, turn the key, starter gives a micro-second burp and then entire electrics on the Puma are dead, nothing, no lights, horn, locks, windows, fans, nothing - it's dead. Disconnect the battery terminals then reconnect and all is OK.
I've put it down to a dead short on the starter and have ordered a replacement.
I've check the earths on chassis and transfer case and everything is nice and clean and tight. None of the leads of the battery are loose, damaged etc.
So I suspect it to be the starter causing the issue, but it seems there must be some other safeguard on the battery circuit that cuts out since everything goes dead when it happens. The fact that de-energising resets something makes me think its either a circuit breaker or a relay in the main circuit but the only two I can think of are the fuseable link on the battery and the starter relay under the driver's seat. But the fuseable link is just that (I believe it is only a heavy duty fuse) and the starter relay I can't see holding everything out.
Any ideas?
