Results 1 to 2 of 2
Thread: Fuel filler flap mechanism
    Melbourne, AU
    My filler flap wont close as the pin has disappeared. I can hear the mechanism working but must have dropped into the interior. Rave isn't helpful about accessing that area...
    Do I get at it from inside the car or underneath? thanks ahead of time.
    Just found it in RAVE... looking in the wrong place.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Ringwood, Vic
    I had this problem on my previous car.
    I just fished around with a bit of fine wire through the hole and pulled it back up.
    What I did next was to use the end bit (where the point comes out) of a biro, cut it down a bit and screwed it into the hole with the pin in the middle. Never had the problem again. Crude but it worked
    D4 SDV6, a blank canvas
