Results 1 to 6 of 6
Thread: Spark plug leads
    Nov 2008
    Spark plug leads
    Is there a particular specification for spark plug leads for a 1971 IIa 2.6L engine, or do they just need to be the right length, with the right attachments at either end?
    My local Repco and Autobarn can't find current parts numbers in their books, but there are lots of leads of different lengths hanging on the wall behind them.
    Should I just measure my old leads and go and buy new ones the same length from Supercheap (Bosch, I think)?
    Roger
    Mar 2012
    Porongurup Western Australia
    I looked at supercheap yesterday and I'm pretty sure they have leads for the 2.6 6cyl. There's not much difference in performance between leads that suit your engine and ones that do as far as I know. My IIA ran of Mazda leads for a long time and never had a problem but when I replaced the leads with new leads and dizzy cap, WHAT A DIFFERENCE! New plugs, leads, dizzy cap, points and rotor arm make a big difference if you replace your really old ones.
    JDNSW's Avatar
    Quote Originally Posted by dreamin' View Post
    Roger
    Yes.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    the magnacore leads i bought for mine were all the same length. and shorter than i thought they would be
    will measure if you want.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Nov 2008
    Quote Originally Posted by incisor View Post
    Did they come as a set?
    I have just looked up Bosch part numbers on the web and they specify same part number for cyls 1-4, and a different number for 5 and 6. Set may be the same?
    R
    sparks are dancing
    Quote Originally Posted by Series3 GT View Post
    ---- when I replaced the leads with new leads and dizzy cap, WHAT A DIFFERENCE! New plugs, leads, dizzy cap, points and rotor arm make a big difference if you replace your really old ones.
    Lift the bonnet of a night and have a look at where the sparks are dancing, that's where the performance is!
