Did you stick your head underneath and have a look to see if anything is out of place......?
Sounds like you may have a short in the reverse light wiring......
Have you damaged a trailer plug or a reverse light recently......?
If you have a trailer plug.....check and make sure no clown has mucked around with it......
On the old style round plugs.....it was always fun to stick a 5cent coin in the plug under the flap.....which would blow all the light fuses as each light was used.....
 ,i'd be looking at the reverse switch on the gear box . If you have a light tester,disconnect power into switch ,and test,asuming you'v put a good fuse back ,test to that point , if ok work back from there , if not the problem is in front of the switch . You can bypass the switch to see if the reverse lights work . You should be able to move your truck . A blown reverse fues shouldn't stop you good luck jimr1 ...
