Thread: early steering wheel
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    as a matter of interest
    is there anything special about a 49/50 steering wheel?
    are they the same spline and clamp as a later version out of an 86"?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    smurf village
    the only difference is the very early s1 had 2 spokes as you probably know but I have had a s2 on a s1 same spline it was just the s2 had the extra cover/spacing bit so yes an 86 will fit the early ones AFAIK
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by incisor View Post
    Or even the SII and early SIIa.
    It's only the 48/49 two spoke wheels that are different but interchangeable.
    bulletproof Guest
    The first 48 steering wheel was a Flat 2 spoke
    These were used until late 1948 when a Flat 4 spoke was introduced
    The flat 4 spoke lasted until mid 1949 when the flat 2 spoke was reintroduced. These were used until 1950 when the dished 4 spoke started being used. These continued right through into the series 2s
    Cheers Richard
    smurf village
    what is the difference between the flat 2 spoke in alnd rover to those they used in rover cars that were 2 spoke?
    I am guessing the thread for one
    1.20 MB
    Quote Originally Posted by Landy Smurf View Post
    Both the 1948 two spoke and flat four spoke ones were used in the P3, they sometimes had a different horn button/centre fitting.
    May 2008
    Bundaberg Qld
    I know of about 5 1948 P3's (including the one in my shed) and I have never seen a 4 spoke wheel on one (until the one in your pic Diana).
    There ya go, learned something new today
    bulletproof Guest
    yes Diana is correct. The flat 4 spoke for the P3 had a ring at the base for an indicator. The Land Rover flat 4 spoke didn't have this .
    Cheers Richard
    smurf village
    Is there a chassis number where the steering wheels changed?
    Are the steering wheels changes listed in the 80inch changes document?
    JDNSW's Avatar
    I doubt it - even if it did change at a definite chasssis number (rather than the usual "alternatives"), since they wheels are interchangeable, I can't see them even recording this at the time. It would have simply been a change by the supplier.
