You can use the s1 gearbox but you will need a s2/2a/3 bellhousing.
The 2.25 should fit in no worries you just need to make different engine mounts
Has anyone done this or aware of one?
In theory what are the pro/con?
Which Clutch/ Gbox/ Trans combination ?
Diff ratio standard or change? or use 7.50 x 16 and or overdrive ?
I have an engine, which will need the bore done and check bearings ect which needs Starter and Exhaust manifold.
I assume the engine will bolt up to existing mounts and utilise current/ or S2/3 radiator .Do I have the option of using current 2l bellhousing/ clutch and gearbox ect? or am I better off using newer alternative?
The idea would be to make the car more economical/ reliable and powerful for everyday use.
Thanks in anticipation.
If you are going to have it as an everyday driver you may want to put in a s2a or s3 gbox
Just wondering why do you want to do the conversion on a s1?
The engine will fit, but will be pretty tight - Rover found it necessary to increase the engine space and wheelbase by two inches to fit it in. I think the mounts fit, but you will need the 2/2a or 3 bell housing. You should fit the diesel clutch.
The engine is designed to use the same gearing as the petrol engine, so there is no need to change. Power is up compared to the 86's petrol engine (just) and torque is much lower rpm. The gearbox, transfer case and diffs remained essentially the same from when the 86 was built to the end of Series production. Later boxes had various improvements, and the late 2a boxes are usually considered the best, but the difference is not much, and all are interchangeable. The transfer case changed even less, although the heavier intermediate shaft is more durable. The Series 3 box is all synchromesh (1/2/2a has synchro only on 3/4) but is usually considered more fragile, and costs a lot more to overhaul.
'51 Series 1 80"
'12 Defender 90
If i was going to put the effort on doing a diesel conversion in a series land rover I would pick an 88 or 109 and put a 200tdi in it
Just a note, if you use the S1 box then unless you use a series 2 bell housing you have a problem with the layshaft bearing size. It is easy to machine up a spacer or match up a bearing to the larger size. Best of luck.
