It could just due to the recent hot weather. During the day the air in the rear airsprings expands more than the fronts so the suspension levels, releasing air from the rear. As the air cools the rear drops lower than the front so the front is lowered to match. Next day the same process is repeated until eventually the vehicle is quite low although I've never seen it lower than about access height. I watched mine do this several times recently.
If you're concerned then the ecu can be disabled by removing the suspension ecu main engine bay fuse which will reveal whether there's an air leak or it was caused by the ecu periodically re-levelling.
