Am I reading that right? Does the third image show that you are doing about 2000rpm at 121km/h?
The other two seem to show between 10 and 11 litres/100km at 122km/h. That wasn't downhill was it?![]()
Certainly happy with these figures!
And based on testing (modified ccf) the readings are mighty close to what the pump says!
Attachment 55878
Attachment 55879
Attachment 55880
Land Rover - For the win![]()
That is impressive! Mine averages that fuels consumption....... never.
Nice to see you've had a cold change come through also!
Slunnie
122km/h, was sir fracturing the speed limit a little bit ?
/ohcomeonsomeonehadtosayit![]()
I maintain it was on a private track on a local homestead![]()
It probably means 2000RPM at 117 KPH given the overread on the speedo.I thought you did a trip to the Northern Territory where the speed limit is 130!
Even if it was on the Hume Highway NSW, it would only be a fine or less than 10KPH over the speed limit and IIRC only one demerit point on your licence.
