its most likely going to be
the tank breather line, the expansion bulge breather (if your version of the tank has it) or the pump sealing ring assembly.
But
It can also be a crack in the tank seams if you're in the habit of brimming the tank and have done so when its cold and then the tanks gotten hot without you drawing much fuel off.
