Thread: Panhard Rods - mod or replace. (D2)
    With any lift you'll need to adjust the rod to re-centre the front axle under the car. However we suffer from a distinct lack of options that are available locally that are reasonably priced, or from overseas that are cheap to freight.
    Looking at the spare (bent) rod I have, it's hollow and I need to lengthen (for my specific needs) about 20mm or so. Was thinking of the following. Cutting and inserting a piece of solid bar up the guts of the rod, drilling into the outer original rod at specific points and plug welding it to giveit attachment and stop it rattling in there. Then cutting a section of the bent rod thats ok to act as a sleeve to take up the gap where it's lengthened. slip this over the inner and then fitting the other end and weld up and grind back and re powder coat to look as stock as possible.
    Given then while it's being cut and welded there’s a piece of (possible HT) solid in there and the outer is welded to it and the other end with the spacer making it complete it should be at least as strong. There should be no real need for adjustment unless you add or subtract lift. Set and forget.
    So what do we think of this? Feasible? Certainly cheaper than any other option. keeps it looking standard. Did a similar thing on a lowered show car (didn't need space as lowered not raised). Since they were abundant and cheap I made a couple and they were stronger in deflection when tested on the press.
    Opinions and suggestions everyone.
    99.87 MB
    How much safe adjustment is also in the drag link also. Personally, I wouldn't even think about cutting and welding the panhard, testing it in the press isn't ally an exhaustive test particularly with fatigue. An engineer would also crack testing/X-ray. I also don't think the mods guidelines allow it.
    Slunnie
    Aug 2012
    Greenvale, Melbourne
    What year is ur car? The reason I ask is that pre d2a/2003 discoveries I believe have longer rods. There is thread here somewhere explains yhe reason why LR made that mode as well.
    It's a 2000, the later ones have a shorter (30mm) rod.
    The drag link is fine. There's enough to adjust it to where is is now so I hope it'd go back to where it should be. The difference between std and raised lengths shouldn't be that much and I could do the same with the drag link to extend as well.
    I know just bending isn't much of a test but if there's a solid bar through the middle and then joined about as well as it's possible to do. I'm more concerned whether you think it's as good as it could be done or there's something that could be better.
    The aftermarket is either expensive as there's virtually no off the shelf stuff here (or suppliers of UK sourced stuff need to bring it in with associated costs), it's custom made with associated costs or buy from overseas, is cheap by comaprison to local but has high (due to size/shape/weight) shipping.
    Feb 2010
    Wangaratta
    I bought a spare one for my d2 that I'm gonna do something similar with. Getting a fabricator mate to look at it soon. Hopefully that and some castor correction bushes will bring back the ride quality I had before I lifted. Will post the results when it happens.
    From talk apparently the bushes aren't the end all to castor correction that most hope. How much have you lifted by? At 2" you should be able to cope with the steering being a little sharper, and I prefer it this way. I have 2" but HD springs make it about 70mm all up and 3deg corrected arms bring it back to about 1.3deg out. sharper but not tram tracking all over the place like it does past 3deg.
    I'm avoiding the adjustable route as I don't want to introduce a point that I'd see as weaker than a solid piece. Using a std hollow bar and threading it to put an insert I'd think would have the potential for being weaker at the join.
    99.87 MB
    Even if you used solid bar, short of going to a larger diameter if it will fit past the diff centre or using higher strength material, you will still end up with the same strength ends because you still need to drill and tap the threads for the ball joints.
    Failures that I've seen at the ball joint have related to the male screw thread having bending loads put through them with panhards etc that have bends in them. Fortunately Land Rover don't do this. Screw threads really are not at all designed to have ending moments in them. I have not seen a ball joint ripped out of the link.
    If you cut it and weld a plug into it then the weld creates a stress raiser which concentrates the bending force into a small area and will make it more prone to cracking.
    Slunnie
    So even if I was to use a 4140 solid core (keeps the OD original (though won't go fully end to end past the diff bend)) which is welded to the outer and has the spacer supporting the outer you think they'd be issues (wouldn't the stress raiser in the outer be offset by the core?) with possible bending?
    99.87 MB
    Quote Originally Posted by clubagreenie View Post
    I think it'd be a really good one if you machine or have it machined as a one piece complete item, ie drill and tap each end for the ball joints.
    Check this website for the welding implications of Cro-Mo.
    High Tensile Steels | Interlloy
    Slunnie
    If making one from scratch, probably from 40mm solid round, how would one go about getting the bends into it. Bending is bending but it would at a minimum require stress relief post manipulation. Possibly annealing prior to and stress relief, hardening and tempering depending on the pre manipulation work done. If this was not done wouldn't you end up with something different to what I proposed but with similar issues.
    It could be possible to sucessfully weld it but what would the implications of annealing the core prior to insertion then welding and then stress relieving, hardening and tempering after manufacture?
