When I asked, it was suggested to go with after market TPMS, as the LR unit only warns of low pressure, not what pressure you have.
 Fossicker
						Fossicker
						Hi All,
Does anyone use the tyre pressure monitoring system provided by LR? If so what is your opinion of it? If using an alternative product I would appreciate members opinions. I will be off roading about 1 month each year and tow a camper trailer.
Thank you
We sell the Inawise tyre monitoring units at work and they seem to be a good unit...
4WD TPMS
I use the Tyredog system on our van, does pressure, high and low alarms and temps too.
I've found its best to wake them up by releasing the valve tops each time, but after that it performs faultlessly. You can by 4, 6 and 8 wheel versions.
Have a look at Trailair http://www.landrovertrailair.co.uk/p...–-pn-39-015/ The system is designed for the D3/4 and integrates nicely. Monitors pressure and temp plus can add a multude of trailers and adds a rear camera.
I use a tyredog 6 wheel system and it has always been reliable. I only use it when doing trips though as the sensors seem to be a target in the city. The one time I forgot to remove them after a trip, 2 sensors were taken.
It detected a slow leak when on the Murray river. Very good peace of mind to have them on the trailer.
The security screws on them are fair but won't stop someone after them.
I have been looking at these from juddy here
SensaTyre
I'm considering this set, as it's internal, and know of someone who has used it for some time. Also does 5 wheels.
 Fossicker
						Fossicker
						And on this question phl: I have the OEM TPMS - yes, only shows low pressure warnings, but works well and at least is inbuilt with no more cabin bits to bolt somewhere; and has saved me a couple of tyres I reckon (although they were the original GY @#$% - now gone anyway).
But for me the main problem has been that the OEM system does not detect a wheel on the rear carrier - sees the spare in the underfloor space, but move it to the carrier - throws constant fault messages.
So IMHO make sure that whatever one you are going with, make sure that it will sense at least 6 wheels, and inquire specifically about sensing locations around the vehicle (and of course trailer/van etc).
I have the TPMS Australia system. I spent ages to decide between internal and external systems.
Decision reached eventually in favour of external.
Cons. Could get stolen, but without knowing the codes they are useless to anyone who takes them. There is an anti-theft device which I don't use as it slows down the tyre pressure changes I make on off road trips.
Pros. In short they work. Easily configured for alarms at various pressures as well as temperature alarms and rapid deflation alarms. Can add extra axles trailers etc easily. Can transfer to other trailers quickly. If needed there is a repeater to boost signal from trailer to reach car. And you can easily fit them yourself. No costs to refit tyres. Not going to get damaged when tyre fitter forgets to be careful. No need to reprogramme when rotating wheels as you simply transfer the transmitter to the new wheel in that position. The receiver fits nicely held in place by velcro I glued to the left of the instrument cluster area. No drilling no damage.
I hope this helps.
