Thread: series 3 sports wheel
    rpawebb Guest
    hi guys, I have a slight problem fitting behind the steering wheel of my series 3 swb. I have purchased a 9 bolt steering boss kit, but have a 6 bolt steering wheel. There was some talk of an adapter plate to accommodate the 6 bolt wheel, but I cannot find any on the net. does anybody have a suggestion, please?
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by rpawebb View Post
    Don't we all.... I just use my belly to steer... maybe pop in to the Series III forum and ask, there may be more answers to be had.
    Cheers - Gav
    Mar 2009
    Royalla NSW
    Steering wheel boss.
    The S3 spline on the steering column is the same a a Leyland mini. This may help find the correct Boss or wheel.
    Jul 2012
    Hear hear!
    Quote Originally Posted by bacicat2000 View Post
    Cheers - Gav
    Me too!
    I got the shock of my life when I first got into my 'new' S3 last year - first Land Rover in years and I didn't recall the older S1s or S2s that we owned years ago being built around the seating comfort needs of rhesus monkeys.
    Breathe in........
    Oct 2003
    Godwin Beach Qld
    The smaller the wheel the heavier the steering and the more kickback you get, I would suggest that you try the original wheel for a few months,and if you are not used driving series vehicles remember to keep your thumbs on the rim of the wheel and not hooked around it,dislocated and broken thumbs are not a good look.
    May 2008
    Bundaberg Qld
    I removed the 2 bump stops from behind the drivers seat to get a better driving position.
    Oct 2003
    Godwin Beach Qld
    G'day rpawebb
    Are you sure that you have a series 3 steering column, as the series 2 is longer than that of the late 2a with the dished steering wheel,by about 2 inches,but if you have non-standard seats, that will lift you body position closer to the wheel, it also depends on you body size,I am only a smallist build so have no problems, but my son-in-law can't even fit behind the wheel,6'2" and90+kgs. they have a Madza 3 hatch and I reconn "he puts it on" definatly a little squishy in there.
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    Quote Originally Posted by pop058 View Post
    its amazing how much difference an inch can make
    rpawebb Guest
    thanks all for your suggestions. I'm just a big lump and am used to the heavy steering. Just need more room
    Oct 2003
    Godwin Beach Qld
    I think that a Disco 1 wheel should fit OK as it is smaller in diameter and has the same splines a quick call to MR Automotive will answer that, Dwayne in spares should be able to tell you, he is also knowledgeable in earlier minis as well
