Results 1 to 10 of 21
Thread: Misfire?
    Nov 2008
    Misfire?
    6 pot land rover engine
    New plugs and leads
    Experimenting with mixture - probably richer than needs to be
    5 plugs black and sooty, #6 grey and clean
    Does this mean no ignition in this cylinder, therefore electrical problem?
    What else to check?
    Narrogin WA
    Need a bit more info.
    Are the plugs sooty when the engine is hot?
    Sooty plugs happen on a cold engine, or if the mixture is too rich, or if the spark is not doing its job properly.
    Have you checked the valve clearances and the ignition-timing before adjusting the carburettor? Always tune an engine in the order of: valves; ignition system; carburettor. Tuning an ignition system can take some time if you are using points and you really need an instruction book to help you get everything done properly,
    Cheers Charlie
    Chris72 Guest
    Just a thought but how old is the fuel in your tank ?
    Cheers Chris
    Nov 2008
    Thanks for the quock replies.
    In aswer to your questions|
    Fuel is definitely fresh
    Drove for an hour earlier today - highway speed, so definitely operating temp
    Will check tappet clearances and points, then carb - thanks Chazza
    Will also test compression in each cylinder, while plugs are out
    If fuel, spark and timing OK, could it be valves?
    Thanks again
    Roger
    JDNSW's Avatar
    Quote Originally Posted by dreamin' View Post
    Thanks again
    Roger
    If valves, it will show in the compression test. And yes, this is a possibility. Make sure that there is not a track on the distributor cap shorting one cylinder.
    If valves, it will show in the compression test. And yes, this is a possibility. Make sure that there is not a track on the distributor cap shorting one cylinder. John
    Stick your head under the bonnet when it's dark, with the engine running you can see straight away where the sparks are jumping.
    Like all engines that have alloy head's, you could have a blown head gasket.
    But the 2.6 does have a tendency to burn numbers five and six exhaust valves.
    It helps heaps if you are both ambidextrous and a contortionist to work on those valves
    Narrogin WA
    Seeing that you have taken it for a good run, then it is probably sooty due to the mixture being fiddled with; however; stick with the plan and start with the valves and compression test. Remember to have the throttle wide open when you do the compression test; the engine hot and record the results wet and dry - good luck!
    Incidentally - how did it run on the road? What made you decide it was mixture being the problem?
    Cheers Charlie
    Nov 2008
    OK
    Compression test (dry) as follows:
    1. 130
    2. 125
    3. 130
    4. 140
    5. 130
    6. 120
    Throttle was open (pedal to the floor), plugs out, battery charger attached for even turning, but engine probably cold and no wet test - I figured if there was a problem that could be rings or valves I will have to get the head off anyway. Also, my compression tester is a bit old and unknown accuracy.
    Taking all that into account, can these results tell us anything? I was expecting higher figures generally but also looking out for one or two cylinders dramatically lower than the others. Low readings overall could be wear, but
    maybe just my guage? #6 (the one with the non-sooty plug) is definitely lowest but only by about 10 psi.
    I also adjusted inlet tappets, fitted and set new points and condenser, and cleaned the distributor cap - both looking a bit old and worn. I have new ones on order.
    Started and idled fine but still a bit rough, 'lumpy'. Turned all the lights off and no visible sparks, so maybe they're staying where they should be, Arthur?
    This all started when she suddenly started running very rough a couple of weeks ago. I think I fixed the main problem by replacing the carb diaphragm
    (Zenith Stromberg) and then went through the manual procedure for setting idle speed and mixture. The engine seems to be very sensitive to these settings, but the adjustments seem very coarse and I just can't get it to run smoothly. Maybe the o-rings on the throttle adjuster?
    Tomorrow I'll clean the carb and fit new gaskets and seals - I still think this is
    where I'm having trouble getting the air/fuel mix right. She drives well enough - sits happily on about 105 kmh on the hwy - but 'pops' and runs rough at idle and overrun, with strong petrol fumes and I would like to know if I am actually using all cylinders!
    Thanks again for your help and advice
    Roger
    catching it's breath
    1. 130
    2. 125
    3. 130
    4. 140
    5. 130
    6. 120
    I do think that the spread of those readings is borderline with that lowest reading of number six cylinder being 20 PSI below the highest reading of 140 PSI, the difference is 14.29%, but that's not enough of a problem to pull the whole engine down unless it is also breathing oil fumes heavily, the most likely problem that has been shown by that test is that the exhaust valves now need some attention.
    According to my workshop manual for a 7:1 compression ratio engine the test should show 140 lbs / sq in, see if you can catch the attention of Blknight.aus for his opinion, as Dave would have worked on a lot more of those engines and more recently than I have.
    good
    Narrogin WA
    Seeing that the engine was cold, I think the compression test indicates nothing to be too alarmed about, but I agree with Arthur that the valves probably need attention some time in the future. A wet-test will confirm if that is the problem, or not, on no.6.; as would introducing compressed air into the cylinder with the valves closed and feeling for air at the tail-pipe.
    A carburettor kit sounds like a good idea Roger, as does the new ignition parts. Is the spark a nice electric-blue? If not a substitute coil of known quality would be a good check,
    Cheers Charlie
