Thread: A/C drain
    bobkins Guest
    A/C drain
    Hi All,
    When replacing Uni-joints on my front prop shaft, I read on a few sites about the A/C drain, which drips water on the double cardan joint and can add to its failure, true or not, mine had rust marks on the Uni-joint end caps. The drain has a small push in plug where the water drains from, I brought a 10mm right angle fitting and some hose from bunnings, and redirected the drain to another spot away from the double cardan joint. A waste of time, maybe, but I had fun
    Jan 2010
    Adelaide
    Not a waste of time at all, it is a well documented flaw, and the resolution is exactly as you have done!
    Nice touch with the 90 degree bend as well
    Nov 2012
    Central Queensland
    I usually have a steady stream of water running out from underneath the car after using the aircon, leaving a decent puddle. Is this normal? I do live in central Queensland so the air humidity is pretty high here.
    Mar 2007
    South Arm, Tasmania
    Perfectly normal mate. My D2 has always done exactly the same thing, especially in humid weather. My D4 does the same.
    Cheers .........
    BMKAL
    May 2003
    On The Road
    mine leaks front and back
    I think its an urban myth,,
    we never drive in the rain?
    the problem is they are not greaseable.
    we'd be better off putting some grease nipples in than worrying about a little water.
    bobkins Guest
    With water always dripping out, I have heard the idea that if you could collect this water some how and direct it to the engine bay, you could have it topping up the wind screen washer bottle?????
    Mar 2010
    mine leaks front and back .
    Makes sense if you have air conditioning in the rear. (HSE)
    There is a condensate drain outlet on the rear A/C unit, passenger side.
    Andrew
    A/C drain
    Quote Originally Posted by bobkins View Post
    Common on SME....
    Jan 2010
    Adelaide
    I agree with you here, why the shaft was released as a non servicable item is beyond me
    May 2003
    On The Road
    Plenty of knowledgeable people on here,,
    The way it was explained to me about grease nipples in general--
    the chance of foreign matter being forced into the bearing ( and prematurely shortening its life) over its lifetime of servicing is greater than the alternative problem of just sealing it.
    so if you look at it like that--
    its just good engineering,,
