Hello.
I just reciently wired up a trailer plug for m old mans 2010 puma.
I found there was a factory plug located near the tail lights on the drivers side. (I had to move a plastic guard and rummage around, but I found it!)
This had all the wires I needed to wire up the plug I just tested with a multi metre to find the correct ones, and tapped into them.
I'm not sure if the earlier pumas have this factory plug, or if the plug has a wire for reverse... but worth a look.
Hope this helps.
Cheers.
Richard.
