Results 1 to 9 of 9
Thread: Disco TD5 no power wont start M @ S lights and battery and oil
    Jan 2010
    QLD
    Well i went to open the car yesterday ( i use the key as i disabled the remote locking and immobilizer) and i had to use mild force to get the lock up as it was no longer power assisted. hmm then when i turned the key to on it beeps at me and the m and s lights flash and the oil and battery lights stay on and the digital display which show the gear selected next to the odometer flashes and the car wont turn over. the battery is only four months old and i tried charging that. seem ok and the lights turn on. anyone had a similar problem. i haven't ever had a transmission problem or any problems selecting gears and the transmission was serviced when i changed the battery 4 months ago. mentioned this as i read that the m and s lights refer to a transmission problem. any help would be much appreciated.
    thanks
    simon
    Jan 2010
    Adelaide
    I would say your battery is the issue, get it load tested to determine its condition
    As it is not very old a replacement would be covered under warranty
    Wouldn't be the first new battery to fail early.
    Just had one in the wife "summer car" (soft top Vitara)... Fail... 6 weeks old.
    Jan 2010
    QLD
    battery was tested today and it's fine....
    fuses all look good
    any ideas?
    Jan 2010
    Adelaide
    Get the codes read, that will give you some idea
    Check battery cable and earth points
    Bacchus Marsh Vic.
    As stated I'd check all the leeds from the terminals to the mounting points.
    Is the alternator charging the system and the wires tight on the back of it?
    M&S lights flashing can indicate low battery voltage so it may not be transmition related.
    Are there any accesories fitted that can drain the battery(fridge,winch,radios)?
    Cheers, Kyle.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Feb 2011
    Brunswick, Victoria
    I had this happen to me yesterday. Turn the ignition, and got the Click, click but not a peep out of the starter, lights on the dash dimmed, m&s started flashing. Batteries both at 12.5V unloaded.
    Got under the d2 pulled the Lucar connector off the starter solenoid, and pushed back on. Gave the end of the solenoid a tap with a spanner. Started straight away after that. Solenoid is slated for a rebuild, but will be checking all connections too.
    Paul
    Jan 2010
    QLD
    Problem resolved it was the battery even though the racq test said it was ok
    South Yundreup,WA.
    Yep the battery may be buggered, but not being very old is it a dodgy battery or something else draining the battery? I would also get the power drain checked with a clamp meter.
    CraigE
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
