                                                5th February 2013, 07:18 AM
			Windows?
					The one touch window closing on my D4 has stopped working. It does work on opening. I had the battery disconnected while I was away for a week. Could this have caused the problem?
 Jools
                                                5th February 2013, 07:41 AM
			Windows?
					Yes that will cause the problem, there is a technique to it. With car on or running hold the button till window goes all the way down, hold button for a few seconds then pull and hold till it comes all the way up hold for a few seconds, then release and then press up for another second or so. Repeat with all windows and should be right!
 Hope this helps!
                                                5th February 2013, 09:01 AM
					Thanks for that....In the meantime I found it in the manual after getting slightly wrong instructions from my dealer!!
