Results 1 to 8 of 8
Thread: Introduction and Question from new D4 owner
    RovingRod Guest
    Hello. Just bought MY13 TDV6 basic model except for leather and 7 seats.
    Had a few Land Rovers and a couple Range Rovers back in 80's-90's. Hoping to look forward to happy relationship with a Rover again.
    Couple issues - steering audio controls don't work and one shot global closing also does not work. Dealer says they haven't been activated before delivery ??? My question is - what does the red strap with plastic lever (under the double drink cup holders in centre console, where the handbrake wire loop release is), activate/deactivate ??
    Thanks.
    Dec 2009
    Quote Originally Posted by RovingRod View Post
    Thanks.
    Welcome! There are many secrets in the Land Rover world, but since you are now part of the club (again) I can tell you that the red strap is the emergency manual release for the EDIT: Correction - Gear Selection NOT electronic park brake (in case it gets stuck with the park brake on).
    Last edited by eddomak; 5th February 2013 at 08:06 PM. Reason: Corrected incorrect information
    And global closing isnt activated in AUS...
    But you can edit the CCF if you get a Faultmate
    May 2011
    Orange Grove WA
    Works on mine.....and at a greater distance than 11 metres.
    Was not activated by dealer or me....it came with the car.
    I Just hold lock or unlock button down for a few seconds....then all windows go up or down!
    Brett.....
    Dec 2009
    SW WA
    I have to push the lock button twice and hold on second push, to get my windows to all go up?
    Thanks.
    Congrats & Welcome.
    Steering audio controls will either be plug not pushed home behind airbag or just a dodgy switch.
    Global closing should work (13MY it's baaaaack) by, when locking & windows open, press the lock button & HOLD continuously until windows close.
    Red strap is to release Gear selection not Park Brake.
    Cheers.
    Sent from my iPad using Forum Runner
    Dec 2009
    Quote Originally Posted by sniegy View Post
    Thanks! Original answer now corrected! (I guess they didn't let me know that secret after all. :P )
    IanB Guest
    Steering Control
    Hi Roving Rod,
    Contact your dealer there is a recall on MY13 Disco 4 for the steering controls not working I just had mine replaced after I called the dealer to ask a question they advised the controls needed to be replaced. Any luck on the Global Closing?
