5th February 2013, 10:44 PM
RR Classic ABS Brake Pressure Switch
Does anyone know if you can get away with just bleeding the hydraulic brake pump nipple after replacing the pressure switch on the pump. i.e. the bleeder nipple is downstream from the switch? Or have to bleed the whole system, static and pressurised circuits? Maybe a lot of fluid escapes the pump when you screw out the switch.
