9th February 2013, 11:55 AM
Aquarium internal filters
Hello All,
Yes I did check and there has been earlier posts about keeping fish in aquariums already posted in the General Chat section
Anyway, I was gifted an aquarium and it uses an internal filter. The filter came without any instructions so I do not know much about it. It is also a different type of filter to the ones I had years ago. They were under gravel filters with air stones and a pump.
I was lucky enough to find the type of internal filter on eBay that my current tank comes with. I have noticed that while this filter handles larger particles quite well there still seems to be a lot of smaller particles that just seem to get constantly recirculated through the filter system and do not get captured. The two gold fish seem happy enough so it is not a problem to them.
The tank is 500 mm by 150 mm by about 300 mm in height so it is not a large tank. I may get another gold fish so it will only have three gold fish in it.
Okay the internal filter is this one... Aqua One Maxi 101F Internal Filter Aqua One Maxi 101F Internal Filter 3 Year Guarantee Aquarium Fish Tank Filter | eBay
Is there a better type of internal filter or should I go up to an external filter?
Are internal filters better than internal filters?
By the way should the outlet of the internal filter be located above the water line so that the water leaving it gets aerated? Or is the water meant to come out of the outlet at or below water level?
Without any instruction manual I guessed that having aeration and some rippling of the water would be better than a stagnant state within the tank. Because you often see aerators such as paddle wheels on commercial aquaculture ponds so maybe the same thing applies to small aquariums?
Well I should have tried eBay before I posted an earlier thread about Fish Pellets! I just found what I think is the same product on eBay too -
Fish Food Pellets Goldfish, Koi & Tropical 2.5kg 6mm Floating - http://www.ebay.com.au/itm/Fish-Food...item20cb5f4785
Now to contact the seller to see if they have an instructions about how much to feed my little friends each day.
Kind Regards
Lionel
9th February 2013, 12:03 PM
the Aqua Ones often had a small nipple on the top of the outlet tube. this was to attach an airline and use the vortex action of the water passing through to draw air into the water stream. Regular cleaning of your filter will keep your goldfish happy and you can buy activated carbon inserts as well as the foamblocks to suit your filter....just clean them in plenty of fresh running water until all gunk stops coming out.
9th February 2013, 12:06 PM
if you dont have the aeration nipple put the outlet at water level so that it does just as you said......the fish like the water movement too.
9th February 2013, 12:16 PM
#4
There shouldn't be a problem with inserting a finer foam in place of the current foam filter.
Slunnie
9th February 2013, 12:25 PM
#5
Good on you for getting some fish, they are relaxing and an interesting hobby. That filter should be okay I think. As far as I know those types should be mostly submerged, however the outlet at the top above water line should be okay for some aeration of the water.
I would just get some goldfish food from the supermarket of a pet-shop, some flakes would do.
You may be better off sticking to only two fish in that tank, as tempting at three may be, the fish are better not overcrowded, the set-up would work better that way.
Ashley
9th February 2013, 12:28 PM
#6
Hello All,
Thank you for the replies they are much appreciated. I will post this message and then click on edit so I can see people's names - hang on a tick....
Thank you Ashley for the caution about the numbers of fish - I do have access to a bigger tank.
Slunnie thanks for the suggestion about getting a smaller size foam.
Ramblingboy42 my version of the filter is nipple-less - poor bugger!
SWMBO is amazed - "we had gold fish in tanks in the kids room for years and you never took that much interest in them!" ... [The gold fish that is :0) ...] Now you have a tank right next to your computer on your desk it is a different story!"
I must admit that it is great to take a break and glance to my right and observe the fish and two snails while I try and think about a better way to phrase something or remember an important point that has eluded my memory.
Kind Regards
Lionel
9th February 2013, 12:30 PM
#7
Yes, the capacity of the tank is asked on surface area for oxygen exchange rather than volume, and gold fish require a lot of surface area compared to most other fish of the same size. Water movement increases the effective surface area but the must always run and of course the water toxin levels won't be sustainable - you will need to do periodical water changes.
Slunnie
9th February 2013, 12:53 PM
#8
G'day All,
The other benefit of the fish is they don't surprise me that much.
I have an old timber teacher's desk and one of my dogs - the Border Collie Jack, likes to sneak under the desk when I go out of the study and get a cuppa. I come back and put my feet under the desk and they meet this big hairy obstruction and it scares the crap out of me!
Kind Regards
Lionel
9th February 2013, 01:25 PM
#9
I love aquariums.
With this type of filtration the focus isn't really on removing particles but to greatly increase the surface area where a biofilm develops. This biofilm of bacteria eats the nasty molecules in fish crap and rotting fish food. I think it is that the bacteria eats nitrates (toxic) and turns it into nitrites (less toxic). It may be the other way around...
Anyway, make sure you do regular partial water changes and you'll avoid many potential problems.
Also, siphon your water out from the bottom of the tank when you change the water. Try to suck up the accumulated crap from wherever it likes to collect.
If you have plenty of aquatic plants in the tank it has a highly beneficial effect on water quality.
9th February 2013, 01:37 PM
#10
Going by my previous experience with 13 tanks I would suggest to you to install a under gravel filter with a power head.
The under gravel filter will do the filtration of the water and promote the good bacteria and the power head have much better water circulation than an air pump and also will aerate the tank much better.
If you are concerned about food waste and no plan to breed fish an addition of a cat fish will keep the pollution at bay.
I used this system (without the cat fish) on standard five 4 foot tanks were over 300 tiny cichilds were kept until they grow to a 20cent coin size.
Remember that a weekly water change do a lot of good for the health of the tank.
