Get a Auto transmission specialist with knowledge of this box to drive it. They will probably want to then remove the pan and check the filter and check for debris. If nothing is found it is likely a flush will fix it.
You could use a transmission from another vehicle except that the ECU for the box is contained inside and the programming is specific to the vehicle. As far as I know no-one has yet been able to flash the ECU and ZF will charge $3K for a new one.
				Fuji white RRS L494 AB Gone
2023 Ford Ranga
