Results 1 to 8 of 8
Thread: My D4 "failing to proceed"
    Queensland
    Damn! Stuck in Brisbane and not starting ~ battery is ok and SWMBO thought she had run out of fuel. I came to the rescue with 20l, but still won't go; fuel pump? I did note as I cycled through the errors screen that it came up Low oil on one occasion -hmmm but when checking oil level I get "not available" ~ maybe it's low and shut itself down?
    Queensland
    Oil level fine; RACQ agree its probably fuel pump (quick spray direct into air filter housing almost caught; fuses fine etc
    So like my D3 - fuel pump at under 50k, sigh, waiting for that bloody flat bed truck - Again!!!!!!
    Brisbane,some of the time.
    Bugga,hope it gets sorted
    Not another one
    Lotza has gone quiet with hers?Wonder what the result was?
    They can be a pain at times to bleed, there is a Schroeder valve at the rear of the engine to bleed air from the lines.
    It is a pain with only one prison tho'
    Hope it gets sorted quick & painlessly for you.
    Sent from my iPad using Forum Runner
    NSW SW Slopes
    Quote Originally Posted by sniegy View Post
    I must try to remember this - I know I was aware of it but needed to be reminded.
    Queensland
    ahhh, thanks Sniegy, I wondered that as I sat there waiting last night! The car was actually booked in at Australs' for a service (Thursday), so at least now they will also get to look at:
    Low fuel warning light coming on occassionally, AFTER filling the car up;
    Passenger window button (on drivers door) not working; and
    Start button "pause" - ie having to try more thna once to start car.
    All issues I have noted with at least one member here or on Disco3.co.uk.
    Lucky I love the beast - it does frustrate me at times!
    cheers!
    Quote Originally Posted by Stornoway SA View Post
    There's an update to the instrument binnacle that might be relevant if this continues.
    Gordon
    Queensland
    Thanks Gordon, I'll see what they say.... I always like seeing if they mention these things first and then raising it if they dont; you get to see that blank stare..."oh, he knows more than I do..."
