Results 1 to 10 of 13
Thread: shocks -more travel
    88classic Guest
    Thumbs up shocks -more travel
    Hey all this is a special thread for anyone that has gone the extrea mile and uses nissan patrol shocks in the rear and ?????? in the front!..
    88classic Guest
    Thumbs down advert
    I really hate peddars suspension on range rovers..
    Its never worked and will not work..... SO WHY ?????.
    99.87 MB
    What was the situation and problem exactly?
    Slunnie
    88classic Guest
    SHOCKS
    Terrible articulation ..terrible bump stop and my haines hunter cornered better..it was terrible ..every pot hole bump you hit you knew it...So did your back.. It just did not work at all....
    Even the pedders franchise owner from Traralgon told me he does not recommend them on range rovers but lets give it a go....
    Never again!!!!!!!. he wqas right......
    88classic Guest
    shocks
    the franchise in Traralgon closed down a number of years ago.
    not sure if anybody fits them or stocks them now in the area..
    dont get me wrong .. my brother had them on is xbgt and they worked fine
    just didnt cut it for the classic RR.
    99.87 MB
    It does sound like an incorrect fitment. I use Patrol rears in the front of my D2 and they need a fairly long spring to work.
    I though it was Landcruiser shocks that people used in the classic coil sprung land rovers anyway.
    Slunnie
    88classic Guest
    shocks
    Nissan patrol in the rears and land cruiser in the front ..
    well thats what im led to believe..
    not 100% sure but the guy working on my RRC races them so Im fullof trust at the moment
    NSW far north coast
    Quote Originally Posted by 88classic View Post
    Yep, TLC 80/100 Series in the front and Patrol rears.
    The MQ/GQ/GU leafer rears are a bolt in but need re-valving other wise they are too soft in bump and low speed rebound, coiler rears need a pin to eye converter for the bottom eye.
    Front 80/100 Series are a bolt in to the front if you raise the towers, otherwise they'll go metal to metal on full bump.
    I minimised the tower raising, (IIRC only 1/4", most lift them 1/2"-3/4") and used thinner rubbers on the shock body side of the pins and had to shorten the bottom pins so they didn't foul the diff housing to maximise bump and droop with Koni's.
    Fitting longer bump stops defeats the purpose of longer stroke dampers IMO.
    Kiwiland
    Quote Originally Posted by rick130 View Post
    Unless it's been done to clear a bigger engine.
    I've fitted Koni from 80 series cruiser. But the damper rates, even though far better than previously, aren't quite right. Does anyone know what spring rate was found in the front of a diesel 80 series? The Koni's are the same for petrol and diesel 80 series.
    NSW far north coast
    Bump or rebound Dougal ?
    I went softer in bump, can't recall which footvalve I actually used, then I changed the stack anyway.
    I'll dig up the oil specs you'll want too, IIRC Koni (Shell) oil was the same viscosity as Silkolene Pro RSF 5wt @ 40*C, but I'll double check.
    I actually did a basic visometric test, had so many cc's of fluid and timed it draining through an orifice at various temps, then, after all that, a certain Koni agent confirmed the viscosity for me.
