Results 1 to 6 of 6
Thread: Help wanted! 93 3.5L auto V8
    coco Guest
    Hello all just wondering does anyone know where I can buy a new TPS for my car as mine has **** itself.
    thankyou all for your time
    regards Anthony
    Kingston, Tassie, OZ.
    the tps are usually very robust, are you 100% that it has failed?
    what symptoms does your disco have?
    jc
    coco Guest
    Question help wanted
    Hey jc
    The symptoms I have is as followed.
    1. while driving the ! light would come on and enging will cut out for 4 seconds then cut back in then the ! light goes out.
    2. while driving on gas the gas would turn off and on once it has done this if you go to stop and the revs arnt high enough the car would stall so when I stop I have to press the gas and brake at the same time.
    3. ive had the LPG serviced and they sayed its good new egnition switch, egnition coil, egnition barrel
    ill have a look at the ECU connection is the connection the black box on top MAF?
    regards coco
    Stilll sounds like a wiring issue, specifically an EFI system meets LPG system interface problem, in other words I immediately suspect the wiring where it switches injectors off when switched to gas.
    Check all the wiring to and from the gas/petrol switch.
    JC
    coco Guest
    Help wanted!
    I have been planning to get the LPG uninstalled do you think that would help or should I get this problem sorted first before doing that?
    I will have a good look at the wires when I get home In a couple of weeks.
    thankyou for your time jc ill keep you updated
    coco Guest
    Question Help wanted for 3.5L V8 disco 1
    Hey JC,
    I have replaced the MAF and the TPS but the car still has the same problem what wires am I looking at where the EFI meets the LPG?
    Regards coco
