Results 1 to 10 of 11
Thread: D2 Bonnet Release
    Brissy! No flannos here!
    D2 Bonnet Release
    I knew it would happen at the most inconvenient time.....and it did!
    Bonnet cable was stretched or bonnet out of alignment I assume (sometimes hard to open) and on this occasion I really had to lean on the release lever. It broke.
    I have searched around the fora for a logical fix but I am thinking of making my own lever ..out of ally or stainless... giving it a longer stroke and better chance of disengaging.
    I eventually got the bonnet open by pulling on the cable with a pair of pliers. I have tried to realign the bonnet catch in lat, long and height but cant seem to make it any less 'hard'.
    Tips, tricks or advice?
    Ralph
    Apr 2010
    South Melbourne
    Hi Ralph,
    Yep - it's a fairly simple job just to replace the whole cable which includes a new lever with a new genuine one. Route it with gradual bends where possible and it will be very easy to pull on again. You align the catch by just finger tightening the 2 bolts where the cable end joins the release mechanism below the bonnet and close the bonnet, open it then retightening the bolts.
    Simon
    it will also help to double check the hinges, if the bonnets ever been off they may not be in place correctly.
    Yes Dave,
    I think that was the catalyst.
    I had the windscreen replaced and although I (and the windscreen man) took care marking and trying to align the bonnet to the body panels, we must have been slightly out.
    Where does one buy a bonnet cable and lever thingy?
    I haven't seen 'em on evil bay so I guess one has to go genuine.
    I'll ring our local fix-it in the next day or two.
    Ralph
    Cant rememebr if its the disco or deefer (real landrover bonnets open with a lever in the grill) but if the sleeve is ok a gear shift cable from a pushbike can be pressed into service. Just be sure to carefully solder the end togther prior to pushing it through the sheath.
    schuy1 Guest
    have seen them on Evil-Bay, not needed 1 yet But MR Auto will have them for sure about 25 dollar? from memory
    Cheers Scott
    Thanks all, I'll grab one in the next few weeks.
    Ralph
    Wantirna South, Vic
    Regards, Will
    LLAMS, FYRLYTS, OL D4 Bar
    schuy1 Guest
    Quote Originally Posted by winaje View Post
    nearly twice what I thought I had seen! Oldtimers must be worse than what I remember it to be
    Jan 2012
    I got my cable from roverlord, 41.50 delivered overnight express, discount for being aulro member, nice bloke to talk to, only prob is the original metal ring on the end that hooks over the catch is about 2 times as small as the replacement which was eurospares branded and the damn thing wont go through the original holes at the front so i had to go behind the hheadlight, surley the td5 and v8 cant be different
    Ken
