Results 1 to 10 of 16
Thread: oil presure warning light on
    Aug 2008
    latrobe valley victoria
    ive got an issue where when at opperating temp i get the oil warning light come on when a/ you stop or b/ coast under no load
    im thinking it may be crap multi grade oil ive been poring through the engine to clean it out {cheep 15/w 30 im only doing minimal kms between changes}
    the sump has been off and oil screen cleaned etc , although im unshure of the oil presure switch as im not registered so not driving it more than a quick nocturnal buzz of 10 ks or so.
    I recon its the oil, but i know bugger all............
    any points to check prior to putting decent oil in her? {penrite classis medium} , really seems only to ocur with youre foot of the accelerator or under no load.
    cheers mark
    ps seems to run like a freight train up to 47mph{fear prevents further progress lol} handles realy well on rough dirt roads as well
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    There are four possibilities:-
    1. Faulty oil pressure switch - best check would be to install a gauge as well, or swap with a known good one.
    2. Wrong grade of oil - This engine was designed before modern multigrade oils, and it is quite likely that the grade of oil you are using is too light. You need to bear in mind that even the worst oil you can buy today is much better than anything available when this car was sold new.
    3. Worn engine, either plenty of clearance on bearings or pump gears. As long as light goes out above idling speed, no problems are likely.
    4. Throttle linkage is rubbing on harness and shorting wire to switch in some circumstances.
    It is not uncommon for older engines to have the oil pressure light to come on when hot and idling, but as long as it goes out when engine revs are increased, disaster is very unlikely.
    Hope this helps,
    Aug 2008
    yes it dose,
    kinda confirms what i was thinking.
    ill check the wiring today and try and get an oil presure switch
    I have a selection of smiths guages out of a seventies rangie, i might see if i can use that.
    thanks
    Narrogin WA
    I agree it is most likely to be the oil, or the switch so change/check them first.
    If that doesn't work, the pressure-relieve-valve is probably gummed up with old oil. The workshop manual explains how to remove it and clean it - it would be wise to fit a new ball and test the spring strength as well,
    Cheers Charlie
    Aug 2008
    anyone know the thread and size of the oil presure switch?
    Put old engine oil in it and see what happens - by old I do not mean used old oil but oil for older worn engines - Shell certainly has a product as do most other oil brands.
    garry
    Aug 2008
    garry
    yea putting penrite classis medium in it, but ill try and check the switch and have a look at the oil presure releif valve while the sump is of{have to change a stud}
    thanks mark
    oil
    As stated use a 30/50 straight SAE oil
    or one of the following
    Thin or diluted oil
    Low oil level
    Choked pump intake filter
    Faulty release valve
    Excessive bearing clearance
    Excessive camshaft bearing clearance
    loose or restricted oil line
    can not find any other reason
    have fun fixing it
    Iam
    Narre Warren South
    garry
    When I was getting my S1 on the road I visited Caltex and spoke to a technical guy. He claimed the 'oil for old engines' 20W60 or 20W75 was OK for a tired Falcon or Commodore but didn't recommend putting it in an 'old' vehicle.
    Extra strain on the oil pump can cause even more problems.
    If it's losing pressure because of worn bearings etc.....
    I ran a 1973 BSA 650 for many years back in the UK. Towards the end of the time I had it, when it was hot the oil pressure warning light came on at tickover. Never had any issues but I did get replacement shell bearings (oversize), big end bolts, crank bush & bearing ready for the inevitable rebuild. Sold it along with all the new bits still running OK.
    A hydrodynamic bearing will run with a gravity feed oil supply so as long as there is still some pressure it should be OK but ultimately it's telling you that the bearings are worn, oil is flowing out too easily so you cannot build up enough pressure in the system. If the bearing shells are worn they lose their ability to collect dirt (sticks in the white-metal) so you will be getting more wear on the journals.
    Hopefully a 20W50 for older engines cures the problem or it turns out to be the pressure relief valve or pressure switch.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    original recommendation was sae 30 oil above 32 deg sae 20 below 32deg
    sae 50 is about as thick as sae 90 gear oil and is what was recommended for the gearbox and transfer cases in the early ones..
    i agree with glen when he said penrite 20w-60 for the old girls power plants...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
