Results 1 to 2 of 2
Thread: USEING A HYDRAULIC JACK ON A RANGE ROVER
    May 2008
    Hi lads just wondering is their any special way to jack the RR up to take a wheel off with a hydraulic jack, as the D3 has to be jacked a certain way as not to damaged the air suspension just wondering if the Range Rover is the same .
    Declan
    Aug 2010
    Sunbury, VIC
    I just bung it under the wishbone or somewhere else solid. Never had an issue. Takes a bit to get the wheels off the ground, and when you drop it down, the wheel you have had off the ground ends up a bit skew if, but once you drive off, everything sorts itself out pretty quick.
    Cheers - Gav
