Results 1 to 10 of 14
Thread: Spring retaining on full lift
    Golden Beach, QLD 4551
    I have fitted Terrafirma 2 lift kit to my TD5 110.
    TF018 Front Springs
    TF019 Rear Springs
    Pro Sport Shock Absorbers
    TF 120 Fronts
    TF 121 Rears.
    My problem is this:
    When Jacking the car up:
    The front springs are shorter than the shock absorber travel. E.g. The can and do move of the seats...rattle about if you like.
    The rear springs retained by the bottom leave the top Spring location and dangle freely. On returning to ground they totally miss the spring housing. E.g sit outside.
    I have heard the springs 'ping' as reseating whist driving on road.
    My concerns are driving off road these are going to be moving around a lot potentially cause damage or an accident.
    Is it normal for rear springs to leave to top seat. I would of thought at all times the spring will have some tension still....be it very little.
    Help, advise, experience please.
    Regards,
    Chilly
    NSW far north coast
    Free length of the springs and open and closed length of the dampers might help.
    Sounds like someone has mismatched your spring and damper lengths.
    Unfortunately kits generally suck.
    Often HD springs are just a stiffer rate to give a taller loaded height, meaning the free length of the spring is the same or shorter than the OE spring.
    This leaves you with reduced droop, (the bump to droop ratio has been altered, but effective wheel travel is only the same, or even reduced from stock) meaning you are more likely to lift wheels in the real world.
    You have what are known in the 4wd community as dislocating springs. The regulations Aus Design Rules and AFAIK every states rules for modified suspension do not permit the springs to be unrestrained.
    Now a lot ignore this fact. In the UK, they love dislocating springs. The problem with the springs re-seating is usually taken care of by re-locating cones.
    My personal choice is that I'm not a fan of dislocating springs for what I do. Retaining the springs makes the vehicle more stable, and retaining the rear springs make the front suspension do more (better balance between front and rear articulation.
    You do need to sort out your problem of the springs not re-seating properly, sooner rather than later. You can join the relocation cone camp, or the retained camp, your choice.
    NSW far north coast
    If it is a long travel kit John you'd think they would supply dislocating cones with it too.
    If they are long travel shocks, eg. 10" travel in the front, there's a bloody good chance they'll go metal to metal at full bump without revised mounts or longer bump stops.
    May 2011
    Brisbane Queensland
    spring seats
    With long travel shocks you have a couple of options -
    Dislocation cones - provided they are bolted in and NOT welded in they will be fine with law enforcement, they are noisy on relocation but work well.
    Progressive rate springs - a bit more work is required to get open and compressed lengths and a lot more expense is involved for a one off order but they are the best option at the end of the day
    Nov 2008
    Gone
    The dislocation/re location cones are a must, so to are the T.F. spring retention plates. As said above, noisy but work well. We had them on the 90 and found them awesome.
    Allan
    Quote Originally Posted by rick130 View Post
    Free length of spring is approx. 415mm
    Centre of top bolt to bottom of Shock absorber is approx. 690mm. This one is from memory. Not sure of closed. Currently on car.
    This is my thought too. Rang the supplier up and he is going to investigate. Are the Springs the correct length...Shocks too long. Not right.
    Quote Originally Posted by Chilly View Post
    TF018 Front Springs
    TF019 Rear Springs
    TF 120 Fronts
    TF 121 Rears.
    My problem is this:
    Regards,
    Chilly
    I would be concerned id a 415mm free length spring was dislocating when the vehicle is driven down the road.What you are probably hearing is the spring reseating,after it has dislocated from the rear,as it is not unusual for the springs to catch on the top spring seats,as a lot of the springs ar made from wire that is minimally thicker than the original wire and the inner diameter of the spring is slightly reduced and hangs on the top spring seat,until there is enough force applied for the spring to force itself over the edge of the spring seat.
    Most pin/eye shocks are measured from the base of the pin to the centre of the eye
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    Quote Originally Posted by LowRanger View Post
    I dont believe it is dislocating. Certainly re-seating. Has to be after you have been over some of Central coasts finest roads thou. Few potholes and bumps.
    Sent a 'contact' a few days back on the terrafirma website...heard nothing...not feeling the love yet...I'll give it till Friday aftrenoon and then send another.
    Dont really want to go relocating cones etc....hey ho
