Results 1 to 4 of 4
Thread: Tail light and park light wiring fault
    Deception Bay
    Tail light and Park wiring fault
    my left side light work and right side don't
    Ran a wire from left to the right side rear bulb connectors and they all lit up. so I recon its where they join up
    Need to know where the left and right side tail/park circuits hook up too each other.
    I am guessing its in the stir fry behind the driving instruments
    Bearman's Avatar
    Hay Point
    Gavo, The left and right have separate circuits and are not connected. I think you will find the problem is the fuse. In the circuit box there is a fuse for each side. From memory I think they are the two on the bottom on the right hand side. If it is not blown give everything a bit of a rough up with light sandpaper and I think you will fix it.
    Cheers......Brian
    1985 110 V8 County
    May 2008
    Mudgeeraba GC
    Do you have a trailer light plug? My left brake/tail light works intermittently and I'm pretty sure it's due to the tail light loom.
    Deception Bay
    All good now bad connection where the fuse is mounted so annoying
