Results 1 to 10 of 14
Thread: Have I overtightened the oil pump bolt (TD5)?
    Jan 2012
    Hi All,
    I'm working down the list of preventative maintenance jobs as found on this forum and today's job was the famous oil pump bolt. I still feel like a total newbie every time I work on the disco and I need some reassurance I haven't overtightened the new oil pump bolt.
    The old bolt was nice and tight with a good coating of factory thread lock. Either we scored a good one from factory or the job had been done before but not documented. (2001 220,000Kms)
    It wasn't a fun job to get to the bolt but I guess it's about peace of mind knowing the engine was safe.
    I sprayed the bolt hole with carb cleaner then used ear buds and compressed air to finish the clean. I also applied a nice smear of Loctite 243 on a brand new genuine bolt which already had some factory Loctite.
    Set the torque wrench to 27nm instead of the 25nm in the manual. Tightened to the 27nm click and went a little more.
    I'm now worried I've overtightened? I can still get solid clicks out of the torque wrench set at 27nm if I re-check the torque.
    I was paranoid about not having the bolt done, but now I'm more paranoid about my work.
    Will it be ok? Sump goes back on tomorrow.
    Cheers Tony
    Jul 2009
    Lake Macquarie NSW
    Mate, relax, it will be fine, I could not get my 1/2" drive torque wrench on to the bolt so I tightened it until the engine started to turn over. That was 2 years ago.
    Robbo
    Jul 2007
    Blue Mountains NSW
    Mate, I did mine today too, Mine was loose and and I replaced the bolt and did it up exactly the same as you, so if yours fails so will mine!!! I think it will be fine.
    Jeremy
    Jan 2012
    Quote Originally Posted by robbotd5 View Post
    Robbo
    Thanks Robbo, I did manage to get my 1/2 inch torque wrench in there which made easy to over-tighten. I think I may have gone a little too far past the engine starting to turn over and thought I felt it turn slightly without the gear turning over? It that possible?
    I'm contemplating removing the bolt before the loctite has cured and refit a new one or the orginal with new loctite in the morning, unless I get talked out of it.
    Buderim, Sunshine Coast QLD
    Robbo
    I used the same method of torque wrench, started to turn the motor so its probably tight enough. Whatever you do, don't re-torque it after the loctite has been applied for a few mins. It may have set and you will make things worse by breaking the bond checking if its tight.
    Jan 2012
    Quote Originally Posted by Jezzaol View Post
    Jeremy
    Thanks Jeremy, Just a little worried as I reckon I may have felt it rotated that extra little bit without the gear moving.
    Saying that, I'm still able to get reliable clicks on the torque wrench at 27nm which tells me it's nice and tight.
    I guess the post below has me a little worried. He was told his bolt failed due to being overtightened. As always I found it after the fact.
    HTML Code:
    http://www.aulro.com/afvb/discovery-2/135177-check-your-oil-bolt-3.html
    May 2010
    brighton, brisbane
    Quote Originally Posted by turbopsi View Post
    Hi All,
    Cheers Tony
    For goodness sake, if after 220,000 km's, nothing has happened, leave the bolt alone. Stop listening to the naysayers, stop being paranoid, it's all good, Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Jun 2008
    Alstonville NSW
    Your not alone. Had a go at my one last winter. Turned out the bolt was in good and proper but changed it anyway. Have a small enough torque wrench to get in there to do the new one up to spec. So probably the whole exercise was a total waste of time but with all the postings about loose bolts what choice do you have if you want to take your disco out bush.
    your fine, I no longer go out of my way to check them but if I have to take the sump off for any reason even if its documented as done I do it anway
    Melrose SA
    Some have failed at over 300 thousand Km so it is probably wise to check them.
    That said I agree with Bob Land Rover owners do get a bit neurotic sometimes
    Quote Originally Posted by bob10 View Post
