Results 1 to 10 of 11
Thread: Tractor 3pl hydraulics not lifting when hot
    Jun 2008
    Drouin East, Vic
    I have a Ford 4100 tractor (actually belongs to my wife even though she refuses to go near it) that we bought a couple of years ago mainly to maintain our driveway as well as odd jobs around the property. It's a late 60's build. I find that when I am using the blade on the 3-point-linkage, the hydraulic performance deteriorates dramatically as the machine warms up. When it has been working for a while, I have to rev the engine to get the hydraulics to lift at all. I haven't had much experience with hydraulics, I'm after some guidance as to how best to address this issue. Is it likely to be a worn out pump or is it more likely to be control valving or something else that is shot. Properly functioning hydraulics would make the machine a whole lot more useful.
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Start with the simple things first . That is if you haven't done so aleady. Check to see if there is enough oil in Hydraulic's If thats O'k you may have to delive deaper in to pump & valve assembly.
    Hydraulics
    Hello,My mate had a similar problem with his Ford tractor,rebuilt lift ram,new hydraulic pump and still played up.Turned out Ford use a specific oil which is shared with the gearbox/rearend/hydraulics,right oil problem fixed.
    Kiwiland
    Re: Tractor 3pl hydraulics not lifting when hot
    Oil frothing?
    sticky or oil
    My first guess is the oil is the wrong type, then look at the relief valve it maybe sticking.
    Jun 2008
    Drouin East, Vic
    Thanks, will check that the oil I'm using is the right spec for starters.
    Kiwiland
    Quote Originally Posted by POD View Post
    It's pretty hard to get the wrong oil in a 1960's tractor. The fergies here run engine oil in their gearbox and hydraulics.
    Check the oil level first.
    Aug 2010
    Sunbury, VIC
    The wrong oil type can cause issues. More modern oils can be an issue as the pump gets old. The pump in your tractor is probably a vane style pump which is not known for its brilliance...
    As they wear, the viscosity of the oil becomes critical. If it gets too thin, it will cause the issues you are describing.
    Cheers - Gav.
    the good oil
    Quote Originally Posted by Dougal View Post
    If the level is down and the pump starts cavitation, that does cause the symptoms described.
    Is the dip stick the correct one for that tractor? check out the following link that shows the different ones available.
    Ford Tractor Oil Level Indicators
    Apr 2011
    Dungowan
    Quote Originally Posted by bacicat View Post
    Cheers - Gav.
    A properly treated (decent) vane pump is a good bit of gear, if operated within its design ranges.
    Most 4100 Ford's will have a piston pump mounted on LH side, rear of engine/front of trans from memory, just above your LH foot. This pump is generally a woeful POS. A replacement gear pump is available from Bare-co and the like, but i think the steel tube need a bit of modifying to fit up. Nothing major tho.
    Think later 4100's may have had a factory fit gear pump, bolted in through the tranny case?????
    Also, piston seal on 3pl ram. Does it have remotes? working or not?
    Generally speeking, from what your saying i'd be at least checking the pump.
    I know a guy thats very good on his Ford tractors if you get really stuck.
