I'm not sure if Puma ones fit.
But I do know that TD5 Defenders had two different frequencies, the earlier ones were 315Mhz, and the later ones 433Mhz. They changed it for interference with radio towers or something.
I think the change over was about 2002 I think.
I have an 02 Defender which is 315Mhz, yet the vin number indicates it should be the 433Mhz. Hence the wrong one was ordered
So check which frequency yours is, and make sure you get one the same.
