Results 1 to 4 of 4
Thread: Compression test 161
    Dec 2012
    Southern Highlands NSW
    Just did the compression test, what insightful reverlations do these numbers give the learned forum members
    Cylinder 1: 127 2: 127 3: 125 4: 110 5: 127 6: 140.
    8.2 8.2 8. 7.7 8.2 9.5
    Cylinder 4 and 6 were tested twice.
    I think 8.2 is about right? cylinder 4 is a little low but 6 seems really high
    any thoughts
    Chris72 Guest
    Quote Originally Posted by gunguy View Post
    any thoughts
    was that a cold or hot motor test ? you should get higher readings on a hot motor test, as long as figures are with in 20 psi of each other it should be good.
    Cheers Chris
    Dec 2012
    all on a cold motor,
    Aug 2010
    Sunbury, VIC
    Posted a reply on your other thread.
