Results 1 to 10 of 39
Thread: An Electric Defender.
    Sep 2006
    Melb.
    Jan 2009
    On the road around Australia
    80km range - will they be installing a line of power points along the Birdsville track too??
    Nice concept, sure, and in a way you couldn't pick a better project vehicle for this than a 110 - drop an electric motor under the bonnet and a ****load of batteries in the back and project's done. But it's a huge step backward from the mission statement of Land Rover from 1948 until now, that is, to go anywhere, at any time. It'll be fine for the soccer moms who use it as a school runabout, but for anyone who wants to use a Defender to even a fraction of its potential, it's a pointless exercise.
    East-South-East Girt-By-Sea
    1.20 MB
    Not sure I agree.
    Firstly LR have said the 7 vehicles are only engineering development platforms.
    Secondly, I am pretty sure there are many farmers or quarrymen who have the need for the 4WD capability on their property but would never travel for more than 80Km or more than 8 hours low range work around the property without returning to the farm house or site office. Not much drama plugging in the car for a top up when you have lunch. The same would be said for a trip into the local village or the next town and return.
    An electric Defender would likely be ideal for underground mines.
    Diana
    May 2010
    brighton, brisbane
    I think it is fantastic LR are on the cutting edge of new technology, who knows what we will see in the future regarding battery development, and innovative ways of charging. It is the way of the future, peak oil is not that far away, and I applaud Land Rover's forward thinking,..... now, if only they could get a defender that didn't leak thru the door seals, Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Jan 2010
    Its 2013 - why the hell are they bothering putting an electric engine to drive the same gearbox, trans, diff set up?! They could have done that in the 80's... Waste!
    I'll get a new defender when each wheel has its own electric hub motor and can be powered by a multi-fuel generator giving it super long range.
    AndrewGJones Guest
    there are only two motors that can deliver 100% of their rated torque from ZERO revs (on the first revolution that is) 1) Steam engine 2) electric Motor.
    fill the roof with PV, install a stirling cycle generator (can run on anything -build a wood fire box and run it on fallen trees!) hermatically seal the electronics and cool them properly... it would be the ultimate bush vehicle.
    would never run out of fuel, has an engine with only one moving component, almost completely quiet.
    they could even have semi-redundant drive lines, one for the rear and one for the front with enough electrickery. or like manic said, in hub motors, you could has quadruple redundant drive capability. No getting stuck anywhere!
    May 2010
    brighton, brisbane
    How about this, I was at the RAN aprentice school when Mr Vagg was getting this organised, Bob
    Graeme Vagg
    Click on the photos to view full size version!!
    1. I found a few photos of my Long Beach steam trike project and the VW steam car based on the fastback body. The trike was a 2 seater and could do 25 mph with a 50cc bump valve uniflow engine and gas fired Smith boiler.
    2. The VW conversion used a 4 cylinder Project Steam 77 and Doble type boiler with a spinning cup burner. I still have the power plant components but did not keep the car body as I wanted something better. It was a cheap platform that allowed a whole system to be tested at the time.
    3. Barrett Mercury 6 steam conversion - 1976. Mounted on a VW bug floor pan with engine connected to the VW transaxle by chain drive. The monotube generator is a Doble type on its side with a pressure atomising burner. The same type of boiler has been used by both Vagg and Barrett is this configuration or vertical with downward firing with 3 different burners, namely pressure atomising, air atomising or spinning cup. My options for solid fuel firing are horizontal or vertcal upwards firing.
    Design considerations for any location include: space available, weight distribution, support arrangements for the tube nest, flue arrangement, air blower requirements to get combustion products through the layout and eventually to atmosphere, mishap management (such as where does fuel drip if there is a misfire or flame out?), ash collection arrangements for solid fuel burners. From an operational point of view you can put a monotube boiler in any position you like and have space for. There would be no restriction on a pressure atomising burner. The spinning cup burners work equally well in horizontal or downward firing positions but would need a slight modification to the cup and fuel supply arrangement for vertically upwards firing. So a lot of design freedom all round.
    4. Vagg Barrett 2 cylinder VW steam conversion. 1976. This engine replaced the Mercury 6 engine and reduced steam consumption by 50%.
    5. Vagg Barrett pressure atomising burner. This was the original oil burner used for the 2 cylinder VW conversion road tests and had a fixed output of 1 US gal/hr that could maintain the test chassis at 30 mph around the back streets of Pomona Ca.
    4. Barrett Triumph Spitfire Steamer. This was the second generation Barrett steam car and used an RJ Smith steam system and a 4 cylinder mercury outboard based engine with various valve gears developed by Barrett. Car was displayed at Los Angeles Car Show around 1975.
    5. Doble Boiler showing water wall tubes around combustion chamber.
    6. Here is another one I forgot and you should have more of this anyway. It is the under hood view of the Besler GM steam car power plant.
    7. I found two pages of colour copies of pictures sent to Project Steam 77 members back in 1976 that include some already posted but give a more complete picture.
    The burner series shows an experimental burner that used two 5 gallon paint tins for an air casing and tested outputs from 1 to 6 us gal/hr. Test was done in Pete Barrett's back yard and gave the basis for a new burner for Barrett's VW steam project.
    My car was built on an extended VW floor pan to take a Fraser Nash replica fibre glass body kit (available in USA at the time). The boiler had the new spinning cup burner developed as part of PS77. I was unable to get a sponsor to leave the car in USA in 1977 when I had to return to Australia so the chassis and wheels were sold and the steam plant and instrument panel returned to Australia where it was used in the VW fastback trials and is now set aside for a similar roadster project when I have time to devote to it. The purpose of the exercise was to show that it was possible to put together a modern steam car that looked good and was affordable, namely less than the cost of a new family sedan at the time.
    8. While on a roll I will keep going. Here is what I found this afternoon.
    8.1 My greatest moment in steam was meeting Barney Becker at his home in San Fransicso in 1976 and having a drive in his beautiful Doble E14.
    8.2. Roy Renner arranged the visit and is shown here beside the car. Roy encouraged me to do something special in steam development and this led to Project Steam 77 being born.
    8.3. Under the hood of Doble E14.
    8.4. The engine compartment of the Besler GM steam car.
    9. Here are two pictures relating to my first steam car project that ran from 1962 to 1968.
    9.1 Original Vagg V4 Uniflow Expansion single acting engine with inlet poppet valves. Bore and stroke were 2.25" and 2". Engine was designed for direct drive to a fixed differential and had a variable cut-off cam shaft with 4 forward positions, neutral and reverse. The engine was designed and built during spare time while undertaking my naval engineering training at the Royal Naval Engineering College, Manadon, at Plymouth, Devon, UK. Various parts had to wait until I learnt how to make them - such as pattern making, iron and aluminium castings, machining and heat treatment etc. One challenge for the instructors was the method of making a heat treated variable cut off cam shaft. The instructor said the item I described couldn't be made. My response was that ity must be possible as the Williams engine had a camshaft that fitted the performance requirement. I did not know until some 40 years later that the Williams camshaft was fabricated with separate cams fitted so was not made in one piece like mine. So with blind faith we made a one piece unit.
    My training finished late 1965 and the engine and boiler parts were shipped back to Australia for completion in 1966 when they were fitted to a new chassis (a Triumph Herald for local insurance compliance requirements) for testing. As the testing program commenced, two developments in the USA made the engine obsolete. First the infinite variable rotary valve design by Richard Smith gave very precise control of engine power at any speed and was virtually silent, Second the use of soluble oil in steam allowed sump lub oil to be eliminated from the system. The engine had automobile shell bearings so was not suitable for soluble oil lubrication so I quickly designed and built a slightly larger engine with a roller crankshaft and rotary inlet valve within about 2 months in about 80 hours of actual working time.
    9.2 The car body selected for the Vagg Steam Car in 1962 was the UK built Falcon Caribbean fibreglass kit made for pre-war Ford 8 and 10 chassis. It was light, attractive and had a suitable shape to accomodate the steam plant in normal space allocated for a petrol engine and drive train. An operational kit car was purchased in 1962 and a second chassis with independent front and rear suspension was purchased for. This had to be rebuilt to fit inside the body shell. The car was registered for road use in UK and Australia and was driven with various petrol engines while waiting for the steam plant. Steam car development work ceased in 1968 when the body shell roof was wrecked in a wind storm at a painter's workshop. The loose body was on a trailer and the wind blew it off and it landed upside down. A commercial developer for the steam plant had been found but expected applications were only for boats and industrial equipment. A second developer, wanting a steam engine for a new sports car project, offered me one of his cars as a substitute for mine. Commercial developments then commenced. Steam club activity did not start again until late 1974 when I had a Navy posting to Long Beach Naval Shipyard for 2 1/2 years. Long term steam contacts Richard J Smith and Peter Barrett were only 20 minutes or one hour away and the rest is history.
    Karl, we did know about you but you had moved elsewhere so we did not meet. Just think what we might have done if you had been involved as well.
    9. Here is a clear picture of one of my V4 rotary inlet valve, uniflow exhaust engines. It is similar to the one in USA now owned by SACA President, Tom Kimmel. These engines have a 3" bore and 2" stroke and a roller bearing crankshaft lubricated by soluble oil in the steam. The RJ Smith type rotary valve was developed separately by Graeme Vagg from a sample single cylinder valve made by Bill Jones, Sydney, Australia following consultion with Richard J Smith. The valve had infinite variable cut off from zero to 80%, both forward and reverse. A spectacular feature of the engine was running it at 4,500 rpm on no load and throwing it into reverse in about one second and repeating the exercise several times in quick succession.
    10. The prototype engine above was used to road test the first Vagg steam car chassis at the RAN apprentices school at HMAS Nirimba, Quakers Hill, NSW, Australia in 1968."[ Yep saw it happen , Bob] " This event is still a great bar room topic at Navy engineering reunions. A sponsorship to develop the design for commercial (non vehicle) applications followed. Before this orders for several engines had been received and agreed for production by the sponsor. By 1976, direct drive engines were out of favour and simpler fixed valve engines running at higher steam conditions with a transmission, were giving better results on the road. There have not been enough new steam engines in cars to settle the debate on this topic but the comparisons found in the Barrett car that used both types of engine in the same chassis were light years apart.
    11. Doble E14 Exhaust Turbine Condenser Fan. The fan shroud can be seen between the boiler and condenser.
    12. Williams Steam Roadster 1961. This attractive picture was well circulated in 1961 by Light Steam Power in a brochure and on the magazine cover and was the inspiration for me to build a modern steam car. My interest commenced some 6 years earlier when I read an article in a motoring magazine about a car that pulled up to a service station without noise, picked up some waste sump oil for free fuel, topped up the water tank and drove quickly off. Way to go I thought. Sounds like the reporter spotted a Stanley Steamer. Anyway the Williams steam engine was far too expensive for me at the time so I bought a stack of plans from Light Steam Power and started to build my own system during my engineering course. By 1966 I had a system a bit like the Williams one for 1/10 the cost.
    13. Barrett Mercury Steam Conversion. This engine was used in the Spitfire project and used twin rotary inlet valves and uniflow exhaust.
    14. Mercury Steam Conversion fitted in the trunk of the Barrett Steam Triumph Spitfire. This car had an independent rear suspension with a fixed differential so mating a steam engine to it was quite easy. Valve and steam system development was an on going process involving extensive correspondence with Graeme Vagg in Sydney, Australia commencing in about 1966 when both started building Smith steam systems and needed to develop designs further.
    15. Barrett Steam Triumph Spitfire with front mounted R J Smith type monotube steam generator made by Peter Barrett. This car was used on the road until 1975 when it was replaced with a VW based vehicle that led to the current steam sports car being built.
    16. Barrett Steam Bicycle with Smith type flash steam plant. Single cylinder engine had a bump inlet valve and uniflow exhaust. I think rider is David Barrett.
    17. Close up view of Barrett Steam Bicycle power plant. These were quite popular in the early 1970s and a number were built. I used a similar plant in the steam trike project.
    18. Barrett Steam VW Power Plant. The main components, namely the 2 cylinder engine, monotube boiler with spinning cup burner, lube oil centrifuge, and throttle valve are clearly shown. The engine uses poppet inlet and exhaust valves and was developed from the original Project Steam 77 design that also only used 2 cylinders in this car. The whole power plant has been progressively upgraded over time to improve component reliability.
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    why do they want to improve the defenders on road driving? It will only be to detriment of its off road capability. If you dont like driving a defender on the bitumen, dont buy one!
    AndrewGJones Guest
    Awesome stuff, Bob. I've always loved those small steam engines, also anything to do with stirling cycle.
    that Doble E14 would have to be the best looking road car ever. Fully bloody stop! And with a chopped roof! that is sheer style.
    It is encouraging to read that LR is experimenting with the Defender platform, gives some hope that is will survive in some guise.
    Safety Bay
    Quote Originally Posted by manic View Post
    Thats not only achievable but a viable option,the weight saving in drivetrain componants not to mention having four self driven wheels effectively making it a true 4wd machine would more than compensate for a battery pack and generator under the floor. Pat
