28th February 2013, 04:38 PM
Pairing SLS remote with vehicle using Nanocom?
Anyone know how to pair the SLS remote control with the vehicle? I have a Nanocom Evolution unit here. It is a brand new unit (Part number STC 50075) to suit the 433MHz band and has the barcode label attached.
28th February 2013, 04:52 PM
Same way as the key fobs
Make sure you have the latest firmware on the nanocom and enter the code from inside the fob in the bottom section
That's how I did mine anyway
28th February 2013, 04:55 PM
It is entered into the BCU - On a Nanocom it is found in the same area that you enter the ignition key fob code.
28th February 2013, 08:13 PM
#4
I can confirm that it's done the same way as the key. I successfully paired a new suspension fob up about 6months ago using my nanocom.
Steve
