I dont know your size and weight but i've not had a problem driving 900klms in one hit in my disco, maybe your seats have sagged ?
I drove the new (old) Disco for 400+ kms yesterday and am sore as, well .. I'm very sore today.
Across the shoulders (where seat is very hard) is one thing but my thighs are aching !!! (due to pressure from seat base)
I find it staggering that the seats in a Disco can be less comfortable than those in a Defender !
I think one of the issues for me is that the seat is not height adjustable (only recline and back/forward)
So solutions welcome but ideally ones that are not TOO expensive. I'm not interested in $1600 seats - just can't justify that - but if there are other aftermarket seats, or seats from other vehicles that just bolt in I'd be interested to hear.
Thanks.
(P.S. Otherwise I'm pretty happy with the car and will put up some pics in next few days)
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
You've given the solution yourself ....................................
Trade the Disco for a Defender
Seat problem solved and as a bonus you'll be able to attend the Qld Defender Day.![]()
Roger
if you find the defender seat comfy why dont you put defender seats in your disco? may defender drivers in the UK put disco seats in there defender so at a guess I would imagine they would be a straight swap and if not I would imagine not a lot of mods to get them in
Hi mate
I find the same thing, get some seats out of a range rover 86 - 93, they are wider and have an arm rest.
Change the complete seat and base and they will fit. There are captive nuts on the side of the trans tunnel to mount the rangie seats in the disco.
As for price, there was a set of leather seats in the give away section of the markets, don't know if they are still there or not.
Happy sitting
Neale
I was wondering whether Classic RR seats would fit? (and whether they are obtainable at reasonable prioces 2nd hand).
Probably the biggest issues is around the lack of (inability to do) up and down adjustment of the seat, A squab which tilted would also probably be handy but less essential.
I would imagine to fit some seats that raise up and down it requires different seat mounts as the current ones seem to be fixed height / can't be changed.
That's why I was thinking RR seats might work but I have no idea if that's actually the case.
gone
1996 Discovery 1
current
Hmmm.. did some googling.
Found out D2 seats don't fit into D1 easily.
Did find this interesting....
Fitting Range Rover seats in a discovery
My concerns are:
1. Legaility.
2. Would this system retain the same "crashworthiness" (i.e. not compromise safety)?
3. Availability of RR seats.
gone
1996 Discovery 1
current
On that site you posted, they would not be legal.
Look at the second pic, top line, see where the radio mic is sitting on that hump in the tunnel. Lift you carpet in that area and there are two captive nuts (may have plugs in them), both my discos have them (93 & 96).
He also used the disco bases. Use the rangie bases and they extend over to these captive nuts, so would be legal as you are using factory mouting points.
Find someone with a late 80s rangie and have a look at the difference in the base. The outside mounting point is the same as the disco.
Hope that all makes sense.
Neale
Sure. On a completely different noteplease advise where you park your Defender and when unattended.
Don't worry ....you'll have a nice Tdi Disco to console yourself with....
TeamFA - it did but you shouldn't point it out if you want your tools back...
Neale - thanks. So specifically then what years should I be looking at as far as RR seats go. (I wouldn't mind electric, but would be quite happy with manual assuming they have the up down etc adjustment/s.
gone
1996 Discovery 1
current
