Results 1 to 8 of 8
Thread: Series 1 Parts Catalogue
    Qld.
    Complete catalogue of Series 1 Part numbers which can then be input to parts suppliers search functions.
    2007 Defender 110
    1993 BMW R100LT
    Gilski Guest
    Parts catalogue
    Thanks Scallops,
    the parts lists are unbelievably helpful
    Qld.
    Quote Originally Posted by Gilski View Post
    Thanks Scallops,
    That's what we aim to do - provide a resource. Glad it was of service to you.
    2007 Defender 110
    1993 BMW R100LT
    caebryn Guest
    Parts catalogue
    Quote Originally Posted by Scallops View Post
    Hi scallops ,how do I download a parts catalogue of series 1 and discovery 1 thanks Hayden
    Logan Village area S.E. QLD
    Quote Originally Posted by caebryn View Post
    You should just click on it and it will download. If you go into the "shop" at the top of the page left hand side there are several CD's that can be purchased which are very helpful.
    Series Landy Rescue
    Our FB Page..
    Qld.
    As mentioned clicking on PDF link will open it......but these links are for the Series vehicle Series 1.......not a modern Discovery. I don’t have any links for them, but I’m sure their section of the forum will be able to help you out.
    Dan.
    2007 Defender 110
    1993 BMW R100LT
    bruttabestia Guest
    Series 2 , 2 litre diesel of 1960 accelerator linkage
    Good afternoon, I need to reassemble the linkage of my 2 litre diesel and i need some help: the parts catalogue indicates 2 springs (item nr. 37, part nr. 277502) and 1 "anchor" ( item nr. 38, part nr. 277565) both on page 155 of the Series 1 parts catalogue ( it the same setup for the Series 2 , 2 litre diesel).
    Can anybody post a picture of an engine where i can see how both springs and anchor need to be fixed, please ?
    Thanks a lot
    The location of the springs is shown on page 5-A2 in the Series 2a manual. The throttle return spring is between the lever on the side of the pump and the shaft of the bell crank that is on a bracket bolted to the top of the pump. The return spring for the stop lever goes to a teardrop shaped bracket held by the upper bolt holding the oil filter adapter, directly below the lever. Looking at a couple of different manual pictures, it seems likely that the setup may have varied somewhat during 2 litre production! (or some of the pictures are from prototypes!)
