Results 1 to 10 of 11
Thread: 300tdi fuel pump modification.
    Feb 2013
    Upper Mt. Gravatt, QLD, 4122
    Help! Just upgraded my intercooler but I cant seem to undo the four flat head screws on the fuel pump to turn the diaphragm. I have managed to loosen one screw but the others wont give. I am nervous about shredding the screw head and have sprayed with WD40 to no avail. Any ideas anyone? Surely i don't have to go to a real mechanic to get a screw undone :s
    Kingston, Tassie, OZ.
    very common, i would suggest a large flat screwdriver at an oblique angle placed on the top of the screw slot and gently tap it around in the anticlockwise direction with a hammer. do not use an impact driver in a vertical direction!
    jc
    Feb 2013
    Thanks jc
    Oct 2007
    wetherill park
    Quote Originally Posted by Hopton1973 View Post
    They can take a bit to crack loose. Did you get a allisport intercooler they say to turn the diaphram 180 degrees we did one about 6 months ago and the EGT went off the scale try 45/90 deg to start with and build up from there we did a head gasket so being wise after the fact
    Oh and make sure you have an egt gauge
    done right it will make a huge inprovment
    NSW far north coast
    IIRC I think I used a gun screwdriver kit which uses fitted drivers (ie. parallel, not tapered sides) and a ratchet drive handle.
    I use it for anything where screws are either hard to access or I might have problems undoing a screw.
    An ordinary screwdriver tends to 'cam out' due to the taper of the driver, a parallel sided driver that's fitted exactly into the slot won't.
    I use my impact driver, its got a nice fat rubber sheath on it thats about the thickness of a V can. (and its got parallel ground tips)
    Feb 2013
    Quote Originally Posted by THE BOOGER View Post
    Yes, got the Allisport intercooler and already a significant difference as the turbo was already upgraded before I got the car. The previous owner has said not too touch the fuel pump but not sure why. It can't hurt to have a tinker can it? Maybe I should get the EGT first to cover my ar*e. Thanks.
    Come on over if you like, I'll be tweaking SWMBO's disco at some point. (and fitting the boost gauge properly and the EGT gauge.)
    Feb 2013
    Thanks Dave that sounds really good. When you know when email me at hopton1973@hotmail.co.uk. Thanks Jeremy.
    Feb 2013
    Thanks for the advice
