Results 1 to 4 of 4
Thread: Too much of a good thing
    May 2003
    On The Road
    I needed a new 12V air compressor, the last one was a (ten year old) $20 cheapy that finally ran out of puff blowing up balloons.
    So I'll buy a bigger/better/more expensive one.
    This one in fact
    The good news?
    well it would inflate an anvil if you asked it to,,
    the bad news?
    the power cable(note the use of that word) has an inline wedge fuse holder,, out of the box it has a 50A fuse,, laugh? I had tears running down my face,, you silly chinese people. So I pulled the 50 and replaced with a nice conservative 10. The sound of the on switch clicking and the fuse blowing were simultaneous, 15A? the same. 20A? well it didnt blow straight away,, but then it wasnt connected to anything to blow up yet! The suby spare was its first victim. The pressure guage showed 25psi(not bad for 5 years), clicked the on switch and blam. A 25A fuse actually let it run for ten seconds, more than enough time to add ten psi to the spare, then blam.
    I utterly refuse to put a 50A fuse back in it.
    but so much for running it off the outside 12V caravan connection.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    now you know one of the main reasons i use anderson 50amp plugs on all my 12v stuff....
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Dalby
    Why do you refuse?
    My single piston ARB current model compressor has a 40 amp maxi blade fuse.
    So long as the wiring is up to the job there is nothing wrong with a 50 amp fuse.
    I see it has alligator clips to connect directly to the battery so that part should be fine.
    May 2009
    West Gippsland - Victoria
    A quick look on eBay shows that 30 amps is the typical maximun current quoted for a twin cylinder compressor of this type. That is when they bother to quote a figure. So a 50 amp fuse isn't out of order as 30 is too small, I've not seen a 40 amp so 50 amp is just right.
    I'm with Inc, anything over 10 amps I use an Anderson connector.
    Deano
