Results 1 to 10 of 21
Thread: 110 Auto conversion
    Landiheaven Guest
    110 Auto conversion
    Hi to all, I'm new to the forum and was wanting sum advise on converting my '85 110 3.5 lt95 to 3.9 zf 4hp22, seems it'l be a bolt up for the most part, just the trans tunnel and lt230 box lever have me wondering what to do, the disco doner has the transfer lever coming out very close to the seat box end of the tunnel, and as for the auto shifter, not sure where to mount it? I could forget the middle seat and cut a nice hole and mount the shifter on the seat box below where the middle seat would have been? however I don't really want to do away with the third seat! any Ideas? thanks so much, great forum!
    redrovertdi Guest
    Use the transfer lever mount that comes/bolts onto the ZF, the lever position is slightly to the left of my tunnel but still in front of the seat box, my t bar is mounted between the hand brake and transfer lever but mine is a 95 110 and has a fibreglass gearbox tunnel, i covered the manual gear lever hole.
    Richard
    Landiheaven Guest
    Thanks Richard, The LT95 tunnel piece that attachs to the seatbox has an inconveniant bulge right where you put your T Bar, maybe it's not needed with the new LT230? thanks Martin
    trumby Guest
    welcome.
    This is a good idea apart from limited down hill engine braking you get with a manual box but I can live with that. I to am looking at doing the same so If you decide to do It pop it under Projects and Tutorials and remember the rules lots of pictures. I have a silver duel cab ute series 111 stage 1 [see youtube land rover custom] but also have a 1985 110 for which I wont the coil spring and power steering set up, so its a body swap, with fire wall mod. But for a carton of beer I bought a rrclassic so I was planning on cutting the tunnel and transmit ion support out of that and using its trans cooler for my fix. Anyway welcome and good luck.
    Landiheaven Guest
    Yeah I will do if I go ahead with it thanks! LT95's are getting a little thin on the ground here, possibly just maybe, if I could rebuild a 95 to not graunch and sort the horrendous backlash, oh and change the high range gears to at least 1.174 instead of the 1.33, I would retain it. Also I would have to find a way for the 95 to run a VSS as I think the 14CUX needs some input to determine if the vehicle is moving or not
    Dec 2009
    Williamstown, Barossa, SA
    What ratio transfer case is on the back of your auto? Going from disco to 110 you might have to drop it a ratio.... I have a 1.222:1 and a 1.410:1 in the shed, but am looking for a 1.192:1 as I'm fitting a Tdi and 5 speed into a SWB Ser 2 rag top. The wife's request was a light, responsive 'fun truck' based on a Series vehicle. Should fill the criteria eh!! PM me if interested. Cheers!
    Landiheaven Guest
    Hi there, I reckon 1.4 gears would be way better than the 1.211 of the disco in a 110. I have a RR 1.192 lt230 in the shed also and a 26d 1.003 ratio if you really want to cruise! Freight a problem, in NZ here though
    Landiheaven Guest
    Sitec, We all need wives like yours! If only mine would share my enthusiasm for them like yours, Hoping that converting to auto will get her in the 110, maybe!
    redrovertdi Guest
    Mine is a 300tdi 110 with disco zf4hp22, i changed the transfer case later to a disco lt230 for the taller gearing which dropped approx 400revs[at 100ks], i do alot of rough off road and the auto in low first behind the diesel[not petrol v8] is brilliant.
    Richard
    Dec 2009
    Damn! 192 and 003! Both boxes I'd have been very interested in but didn't spot the NZ bit.... Are the gears interchangeable in these boxes or are the casings different....? Have a workmate who flys in and out of NZ every 2 weeks... He'd look a bit odd carrying an LT230 on as hand luggage!!! As for SWIMBO, yeah, very lucky there, we have this agreement tho, if I blow $1000 on silly locking diffs and stuff, she gets to spend the same on 'other stuff'.... Just happened last time that she needs an LT77 and Tfer box for the project... Win win for me, Lockers and a gearbox in the shed! Could only find 1.222:1 tho not the 1.192:1 which I think would give the light truck the legs it needs!! As redrovertdi said, I'd try the 1.222:1 before changing it, my 130 with 1.410:1 is flat flat out at 120kph even running 285's!
