yep, not legal and it will make the steering heavy because it effectively increases the castor.
if you want to lift leafers (legally and without upsetting geometry) you either get the springs reset or changed Or you extend both the mounting points downwards by the same amount (you can add shackles on one side but you must relocate the "held" end the same amount)
