If you need the strap and you don't pull the tree down onto the car, then how do you safely remove the strap. If its that sketchy perhaps you'd have to make a call on driving it.
So is have been contemplating this, suppose you need to descend a slippery muddy hill with trees or a drop off at the end.
Now you could winch down backwards if you have a front mounted winch. But if you want a simpler safety back up or you don't have the winch what do you reckon about this.
1 or 2 snatch straps, secured to a tree at the top and the back of the vehicle. The idea is not to use them at all. But they are there as a back up in case you lose traction and can't stop at the end. You would be in low range (HDC if you have it etc so hopefully as slow as possible and the snatch strap has some stretch so it would have a but of shock absorbing at the end.
I have never heard this advocated (maybe with good reason). What do you think would it work or are you likely to remove a section of your car when it slams to a halt at the end?
Slunnie
I would keep my wheels in any ruts, lock in the rear diff (ARB Locker), low range first gear (mines an Auto) and drive it down on the throttle.
If there were no ruts or an embankment to stop you sliding of the actual track, then I would find another route, not worth the risk to vehicle or self if there is a dangerous drop-off, Regards Frank.
As with any off road obstacle that you arrive at... 1, do you need to drive down there, or is their a way around? 2, If you do, once there is there a way out? Attaching straps then sliding down the bank to the length of the straps sounds like a recipe for disaster to me... One Land Rover at the bottom of a hill, with a Pine Tree attached to the end of the strap, no longer attached to the ground! If you HAVE to go down, then I'd be reversing down using the winch cable on a double line pull so you know you have enough winch power to get yourself back up! If the line is not long enough to get to the bottom, then you tie off half way down and go again. Can you paint us a better picture as to why you have to go down there... We're all curious!![]()
Thanks for all your thoughts, its not a real situation I am planning, i just watched a Youtube video of a 4wd sliding all the way down a track and into some scrub at the bottom a while ago and it got me thinking of how to do it better a purely intellectual excercise. Your points about not doing it if it is that bad are well taken and I agree. I guess it might happen if you were camping and it rained seriously while you were camed somewhere and you needed to get out for example.
Why does no one carry wheelchains any more ?
a set of chains on the front wheels and drive down , used to be standard procedure.
because it kind of does away with the 'tread lightly' mission statement that is pc these days...
We have used a strap wrapped loosly once around a tree at the top with someone adjusting the friction on the strap to tree, to lower the vehicle down matching the speed with the vehicle, if the vehicle starts to get out of control they simply walk around the tree a little more to increase the friction on the strap.
It worked .
If the chains retain traction then the damage could be less than muddies locked up.
Chains aren't necessarily evil until they are used inappropriatly.
